Error reading texture property value from fusion asset
rolandas_vegis
Message 1 of 1
rolandas_vegis
When trying to read texture property value from a Fusion library asset I get the following error:
InternalValidationError : pIProperty->GetConnectedAssetCount() > 0 && pIProperty->IsConnectionEnabled().
This works fine with assets from our adsk lib and this used to work with assets from fusion library, however has now stoppped working.
Demo code:
#include <Core/CoreAll.h>
#include <CAM/CAMAll.h>
using namespace adsk::core;
using namespace adsk::fusion;
using namespace adsk::cam;
Ptr<Application> app;
Ptr<UserInterface> ui;
extern "C" XI_EXPORT bool run(const char* context)
	app = Application::get();
	if (!app)
		return false;
	const auto lib = app->materialLibraries()->itemByName("Fusion 360 Appearance Library");
	if (!lib)
		return false;
	const auto appearance = lib->appearances()->item(0);
	const auto properties = appearance->appearanceProperties();
	for (auto i = 0; i < properties->count(); ++i)
		const Ptr<AppearanceTextureProperty> textureProperty = properties->item(i);
		if (!textureProperty)
			continue;
		const auto propertyValue = textureProperty->value();
		std::string error;
		app->getLastError(&error);
		app->userInterface()->messageBox(error);
		break;
	return true;
extern "C" XI_EXPORT bool stop(const char* context)
	return true;
Replies (0)
