Input parameter of CommandDefinition execute method
siliconlad
siliconlad
According to the Fusion 360 API documentation, the execute() method on a CommandDefinition accepts an input parameter.
How do I access the values in the command that's being called?
I have the following snippet here in one of my commands:
cmd = ui.commandDefinitions.itemById(CMD_ID)
x = adsk.core.NamedValues.create()
x.add('message', adsk.core.ValueInput.createByString('hey'))
cmd.execute(x)
How do I access `message` and `hey` when my other command (with `CMD_ID`) is created?
kandennti
Hi @siliconlad -San.
I am not sure I understand what you want to do, but I have little information on the arguments of the CommandDefinition.execute method.
There is a possibility that you can do what you want by using a text command.
https://github.com/kantoku-code/Fusion360_Small_Tools_for_Developers/tree/master/TextCommands
However, it is more difficult to develop than the normal API.
siliconlad
I've figured out a way around this. I was just curious how I could use the argument for `CommandDefinition.execute` because it looked like it would provide a cleaner solution to what I wanted to achieve. It's weird that it's in the API documentation, but there's indicatino of how to use it?
BrianEkins
That argument was added for possible future use. The Inventor API has similar functionality, and I thought it could also be useful in Fusion. It was never intended as a way to provide all of the required input for all commands, but can be useful in a few fringe cases. It would primarily be used for commands that display a dialog. For example, in Inventor, you could provide the filename and execute the component insert command, and it would bypass the dialog, using the provided filename, and go into the next step where the user can move the mouse around to position the component. Nothing has been done in Fusion to take advantage of this yet.
Brian Ekins
ltomuta
Another promising feature that turned out to be a dead-end. 😞
If Fusion itself does not need it that's no reason not to pass the parameter on to 3rd party commands for them to use.
And yes, it could also be used by Fusion to allow bypassing prompts for files, configurations or even derive selections.
