Incorrect transformation from Occurrence transform.
ProtoTechSolutions
ProtoTechSolutions
We are taking transformation matrix from the occurrences.
But when the joints in assembly are not correct, but In GUI it shows correct position of parts.
And when we try to get the transformation matrix from APIs, it gives incorrect transformation. Please refer attached screenshot.
We are using following code snippet.
adsk::core::Ptr<adsk::core::Product> activeProduct = app->activeProduct();
adsk::core::Ptr<adsk::fusion::Design> design = activeProduct;
adsk::core::Ptr<adsk::fusion::Component> rootComp = design->rootComponent();
adsk::core::Ptr<adsk::fusion::Occurrences> occurrences = rootComp->occurrences();
if (occurrences != nullptr)
       int occurancesCount = (int)occurrences->count();
       if (occurancesCount > 0)
              for (int childOccurancesCnt = 0; childOccurancesCnt < occurancesCount; childOccurancesCnt++)
                      adsk::core::Ptr<adsk::fusion::Occurrence> occ = occurrences->item(childOccurancesCnt);
                      if (occ != nullptr)
                             std::vector<double> transMat = child->transform()->asArray();
Please guide us to get correct transformation.
Please let us know if we are missing anything.
rax2003_7
hey, i hae the same issue. did you solve it?
kandennti
Hi rax2003_7.
I hope it will be transmitted well.
The body of the image is in [Component2: 1].
Move [Component1:1] to the image state.
Next, move [Component2:1] to the image state.
It will be in this state.
Red arrow : the origin of the root component
Blue arrow : the origin of the ’’Component1:1'
Green arrow : the origin of the ’Component2:1’
I will explain in this situation.
Attach the created script.
When you execute the script and click the Body of the model data, the [Component2: 1] Matrix3D is displayed from the root component.
Also, a sketch is created on the root component for confirmation, and a point is created so that it is the same position as the origin of [Component2: 1].
'GetRootMatrix' function gets Matrix3D from root component to any component.
def GetRootMatrix(comp):
    comp = adsk.fusion.Component.cast(comp)
    des = adsk.fusion.Design.cast(comp.parentDesign)
    root = des.rootComponent
    mat = adsk.core.Matrix3D.create()
    if comp == root:
        return mat
    occs = root.allOccurrencesByComponent(comp)
    if len(occs) < 1:
        return mat
    occ = occs[0]
    occ_names = occ.fullPathName.split('+')
    occs = [root.allOccurrences.itemByName(name)
                for name in occ_names]
    mat3ds = [occ.transform for occ in occs]
    mat3ds.reverse() #important!!
    for mat3d in mat3ds:
        mat.transformBy(mat3d)
    return mat
I looked for a way to get root component relationships from deep components like this one.
Only Occurrence.fullPathName (return string) could be found.
Get a list of Matrix3D based on the obtained occurrence name.
From there, it transform in the order of deep position.
I believe that the Matrix3D obtained this way is correct.
The linked script was created using this way.
https://github.com/kantoku-code/ExportWire
https://github.com/kantoku-code/Fusion360-ExportSketchPointsCoordinate
I would like to know if there is an easier way to get it.
