Importing revolved surfaceDXF file into autocad from VisualBasic.net
Revolve.DXF is the file that I was using to verify the revolution of a surface shape as a DXF entity in accordance with the DXF 2012 coding requirements but it does not work in AutoCAD.
This file was stripped back to just the polyline as Revolve2.DXF and this file can be loaded into AutoCAD and revolved into a solid entity in AutoCAD.
Does anyone have any experience with the DXF surface coding requirements as the explanation in the AutoCAD documentation is not clear.
ekinsb
This forum is for Fusion 360 programming questions.  It's doubtful that there are very many DXF experts watching here.  You'll probably want to post your question in the AutoCAD specific forums.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
