Importing CSV Data
Importing CSV Data
Importing CSV Data
Hi, i create a simple python script to import a csv.
I use this sintax outside spyder and it work but when i try to use it in sphyder it gave me some problem.
Does the sintax from some "file" import "class"  work in fusion 360?DataHelper2.jpg
KrisKaplan
Use the relative import syntax when importing modules relative to your scripts path.  For example, "from . import DataHelper".  The reason for this is that your module is not being run as the __main__ module when run in Fusion, so the containing folder is not in sys.path by default (it should not be, and relative imports isolates your modules from other script's sub-modules with the same name).
Kris
Kris Kaplan
xiaodong_liang
Autodesk Support
Autodesk Support
daniel_lyall
here is a import/export .csv that works
http://forums.autodesk.com/t5/api-and-scripts/csv-script/td-p/5925524/page/3
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
