I want to get a proxy from the selected profile.
kandennti
Mentor Mentor
kandennti
Hi there.
I'm struggling with a lack of understanding about proxy.
The data is in this state and is attached.
I use the following code to select the profile. selectEntity is used to select the profile and then try to get the proxy, but I get an error with each one and cannot get it. (The same is true with SelectionCommandInput)
#Fusion360API Python script
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        des  :adsk.fusion.Design = _app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        msg :str = 'Select'
        selFiltter :str = 'Profiles'
        sel :adsk.core.Selection = selectEnt(msg ,selFiltter)
        if not sel: return
        prof :adsk.fusion.Profile = sel.entity
        # test1
        print('test1')
        occ :adsk.fusion.Occurrence = prof.assemblyContext
        try:
            proxy = prof.createForAssemblyContext(occ)
            print('{}:OK'.format(occ.name))
        except:
            print('{}:NG'.format(occ.name))
        # test2
        print('\ntest2')
        for occ in root.allOccurrences:
            try:
            except:
        a=1
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def selectEnt(
        msg :str,
        filtterStr :str) -> adsk.core.Selection :
    try:
        sel = _ui.selectEntity(msg, filtterStr)
        return sel
    except:
        return None
The result looks like this.
test1
Occurrence1:2:NG
test2
Occurrence1:1:NG
Occurrence1:2:NG
Does anyone know how to get the proxy from the user's selected profile?
Best regards.
kandennti
I interpreted it as a proxy if the value could be retrieved by assemblyContext Property.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-911fdac9-e6e7-4e4f-b500-b94bafc347f6
That is, I understood that the elements selected in ui.selectEntity and SelectionCommandInput were proxies.
