I AM
I AM
sHubamyadav016
I AM
sHubamyadav016
essageBox('Failed: {}'.format(str(e)))
Jorge_Jaramillo
I believe the best option could be to copy & rotate & move the panel (body) once you make the holes to it.
That way they will have the same shape.
And in your code, you don't need to code the same body twice.
May tomorrow, I can give it a try.
Jorge Jaramillo
Software Engineer
sHubamyadav016
yes please give try i am not able to do please help
Jorge_Jaramillo
I was able to build it with a copy & rotate & move it from the left side panel.
This is the full script which includes some optimizations to avoid duplicates bodies and sketches:
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        # doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        design = adsk.fusion.Design.cast(app.activeProduct)
        # unitsMgr = design.unitsManager
        rootComp = design.rootComponent
        sketches = rootComp.sketches
        # planes = rootComp.constructionPlanes
        # features = rootComp.features
        sweeps = rootComp.features.sweepFeatures
        extrudes = rootComp.features.extrudeFeatures
        root = app.activeProduct.rootComponent
        # features = root.features
        # Create a new component for the panel.
        root_comp = design.rootComponent
        new_comp = root_comp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
        panel_comp = new_comp.component
        # Create a new sketch for the panel.
        sketches = panel_comp.sketches
        xZ_plane = panel_comp.xZConstructionPlane
        panel_sketch = sketches.add(xZ_plane)
        # Define the corners of the panel profile.
        corner1 = adsk.core.Point3D.create(0,0,0)
        corner = adsk.core.Point3D.create(150,0,0)
        # Create lines connecting the corners to form the panel profile.
        lines = panel_sketch.sketchCurves.sketchLines
        line = lines.addByTwoPoints(corner1, corner)
        # Create an angled line at corner  (147.21 degrees).
        angle = math.radians(-150)
        length = -400
        end_point1 = adsk.core.Point3D.create(corner.x + length * math.cos(angle),
                                              corner.y + length * math.sin(angle),
                                              0)
        m= corner.x + length * math.cos(angle)
        s= corner.y + length * math.sin(angle)
        p= corner.x + (length+5) * math.cos(angle)
        q= corner.y + (length+5) * math.sin(angle)
        angled_line = lines.addByTwoPoints(corner, end_point1)
        # Merge the two lines
        line.endSketchPoint.merge(angled_line.startSketchPoint)
        # Get the root component of the active design.
        rootComp = app.activeProduct.rootComponent
        # Get the left plane of the root component.
        leftPlane = rootComp.xYConstructionPlane
        # Create a sketch on the left plane.
        panel_sketch = rootComp.sketches.add(leftPlane)
        panel_profile_points = [
            (0, 0, 0),
            (0, 0, 65),
            (0, -5, 65),
            (0, -5, 5),
            (0, -795, 5),
            (0, -795, 65),
            (0, -800, 65),
            (0, -800, 0)
        for i_ppp in range(len(panel_profile_points)):
                adsk.core.Point3D.create(*panel_profile_points[i_ppp]),
                adsk.core.Point3D.create(*panel_profile_points[(i_ppp + 1) % len(panel_profile_points)])
        # Now, create a profile from the closed sketch
        panel_profile = panel_sketch.profiles.item(0)
        # Create a path and let it find connected curves automatically
        path = panel_comp.features.createPath(line)
        # Create a sweep input
        sweeps = panel_comp.features.sweepFeatures
        sweepInput = sweeps.createInput(panel_profile, path, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        sweepInput.taperAngle = adsk.core.ValueInput.createByString('0 deg')
        sweepInput.twistAngle = adsk.core.ValueInput.createByString('0deg')
        # Create the sweep.
        sweep = sweeps.add(sweepInput)
          # Create holes on the back plane of the panel.
        # Create a hole on the bottom plane of the panel.
        back_plane = panel_comp.xZConstructionPlane
        hole_sketch = panel_comp.sketches.add(back_plane)
        hole_radius = 8  # Adjust the radius as needed
        for z in range(50, 150, 50):
            # Define the center and radius of the hole.
            hole_center = adsk.core.Point3D.create(z, -40, -800)  # Adjust the position as needed
            # Create a circle for the hole.
            hole_sketch.sketchCurves.sketchCircles.addByCenterRadius(hole_center, hole_radius)
        off_set = 40
        angle_for_holes = math.radians(30)
        xo = 150 + off_set*math.sin(angle_for_holes/2)
        r = 400+ off_set*math.sin(angle_for_holes/2)
        yo = -40
        for i in range(7):
            r-=50
            hole_center = adsk.core.Point3D.create(xo + r * math.cos(angle_for_holes), (yo + r * math.sin(angle_for_holes)),-800) # Adjust the position as needed
        # Extrude the hole sketch to create the hole on the side face.
        hole_oc = adsk.core.ObjectCollection.createWithArray([prof for prof in hole_sketch.profiles])
        hole_ext_input = panel_comp.features.extrudeFeatures.createInput(hole_oc, adsk.fusion.FeatureOperations.CutFeatureOperation)
        hole_ext_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(850))  # Adjust the depth of the hole as needed
        hole_ext = panel_comp.features.extrudeFeatures.add(hole_ext_input)
        # Create a rectangle and extrude it in the LEFT plane.
        top_plane = panel_comp.xYConstructionPlane
        top_plane_sketch = panel_comp.sketches.add(top_plane)
        # Define the rectangle's corner points.
        top_plane_points = [
            (0, 0, 0),  # Adjust the position as needed
            (5, 0, 0),  # Adjust the position as needed
            (5, -800, 0),  # Adjust the position as needed
            (0, -800, 0),  # Adjust the position as needed
        rect_lines = top_plane_sketch.sketchCurves.sketchLines
        for i_point in range(len(top_plane_points)):
            rect_lines.addByTwoPoints(
                adsk.core.Point3D.create(*top_plane_points[i_point]),
                adsk.core.Point3D.create(*top_plane_points[(i_point + 1) % len(top_plane_points)])
        # Create a profile from the rectangle.
        rect_profile = top_plane_sketch.profiles.item(0)
        # Extrude the sketch to create the rectangle.
        extrudes = panel_comp.features.extrudeFeatures
        # prof = panel_sketch.profiles[0]
        rect_ext_input = extrudes.createInput(rect_profile, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        rect_ext_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(65))  # Adjust the extrusion height as needed
        rect_ext = extrudes.add(rect_ext_input)
        side_plane = panel_comp.yZConstructionPlane
        hole_sketch = panel_comp.sketches.add(side_plane)
        for z in range(100, 800, 100):
            # Create a hole on the left plane of the panel.
            hole_center = adsk.core.Point3D.create(-40, -z,0)  # Adjust the position as needed
        hole_ext_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(5))  # Adjust the depth of the hole as needed
        hole_ext = extrudes.add(hole_ext_input)
        #stiffner
        # Create a sketch for the stiffener on the XZ plane
        stiffener_plane = panel_comp.xYConstructionPlane
        stiffener_sketch = panel_comp.sketches.add(stiffener_plane)
        for m in range(0, -600, -300):
            i_points = [
                (0, -270+m, 45),
                (0, -230+m ,45),
                (0, -230+m, 39),
                (0, -247+m, 39),
                (0,-247+m, 11),
                (0, -230+m, 11),
                (0, -230+m, 5),
                (0, -270+m, 5),
                (0, -270+m, 11),
                (0, -253+m, 11),
                (0,-253+m, 39),
                (0, -270+m, 39)
            lines = stiffener_sketch.sketchCurves.sketchLines
            for i_point in range(len(i_points)):
                    adsk.core.Point3D.create(*i_points[i_point]),
                    adsk.core.Point3D.create(*i_points[(i_point + 1) % len(i_points)])
        for iprofile_profile in stiffener_sketch.profiles:
            # Create a profile from the I-profile sketch.
            # iprofile_profile =  stiffener_sketch.profiles.item(0)
            sweepInput = sweeps.createInput( iprofile_profile, path, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
            # Create the sweep.
        # copy, rotate and move left panel
        #  - copy the boby into the same component
        tilt_left_panel: adsk.fusion.BRepBody = rect_ext.bodies[0].copyToComponent(new_comp)
        #  - select the edge to rotate it (the longest, lowest and internal edge)
        tilt_edge = sorted(tilt_left_panel.edges,
                           key = lambda e: e.length + e.startVertex.geometry.x - e.startVertex.geometry.z,
                           reverse = True)[0]
        #  - rotate the body
        move_feature_input = panel_comp.features.moveFeatures.createInput2(adsk.core.ObjectCollection.createWithArray([tilt_left_panel]))
        move_feature_input.defineAsRotate(tilt_edge, adsk.core.ValueInput.createByReal(math.radians(180) - angle))
        panel_comp.features.moveFeatures.add(move_feature_input)
        #  - move the body at the end of the angled_line
        source_point = tilt_edge.startVertex if tilt_edge.startVertex.geometry.y == 0 else tilt_edge.endVertex
        move_feature_input.defineAsPointToPosition(
            source_point,
            adsk.core.ValueInput.createByReal(150 + length * math.cos(math.radians(-150))),
            adsk.core.ValueInput.createByReal(0),
            adsk.core.ValueInput.createByReal(-length * math.sin(math.radians(-150))),
            True
        # combine feature to group all body-parts
        panel_comb_fea = panel_comp.features.combineFeatures
        tool_bodies_oc = adsk.core.ObjectCollection.createWithArray(
            [panel_comp.bRepBodies[i] for i in range(1, panel_comp.bRepBodies.count)]
        comb_input: adsk.fusion.CombineFeatureInput = panel_comb_fea.createInput(
            panel_comp.bRepBodies[0],
            tool_bodies_oc
        comb_input.isKeepToolBodies = False
        comb_input.operation = adsk.fusion.FeatureOperations.JoinFeatureOperation
        panel_comb_fea.add(comb_input)
    except Exception as e:
      if ui:
    #      ui.messageBox('Failed: {}'.format(str(e)))
         ui.messageBox('Failed: {}'.format(traceback.format_exc()))
This is the final result I get:
Jorge Jaramillo
Software Engineer
sHubamyadav016
HELLO SIR THANK YOU GIVING ME PRECIOUS TIME AND ALSO A PROPER SOLUTION .
SIR , I HAVE ONE MORE PROBLEM PLEASE SGIVE SOME PROPER SOLUTION I AM NOT ABLE TO SOLVE .
import adsk.core, adsk.fusion, traceback, math
def run(context):
    ui = None
    try:
        corner = adsk.core.Point3D.create(300,0,0)
        length = -300
                                              0)
            (0, 0, 0),
            (0, 0, 65),
            (0, -5, 65),
            (0, -5, 5),
            (0, -95, 5),
            (0, -95, 65),
            (0, -100, 65),
            (0, -100, 0)
        # Create the sweep.
        for z in range(50, 300, 50):
            hole_center = adsk.core.Point3D.create(z, -40, -100)  # Adjust the position as needed
        off_set = 40
        xo = 300 + off_set*math.sin(angle_for_holes/2)
        r = 300+ off_set*math.sin(angle_for_holes/2)
        yo = -40
        for i in range (5):
            r-=50
            hole_center = adsk.core.Point3D.create(xo + r * math.cos(angle_for_holes), (yo + r * math.sin(angle_for_holes)),-100) # Adjust the position as needed
        hole_ext_input.setDistanceExtent(False, adsk.core.ValueInput.createByReal(150))  # Adjust the depth of the hole as needed
            (5, -100, 0),  # Adjust the position as needed
            (0, -100, 0),  # Adjust the position as needed
        for z in range(50,100,50):
                           reverse = True)[0]
        #  - rotate the body
            source_point,
            adsk.core.ValueInput.createByReal(300 + length * math.cos(math.radians(-150))),
            True
            tool_bodies_oc
      if ui:
sHubamyadav016
sDGgfvdxhn
sHubamyadav016
YOU CAN TAKE APPROPRIATE PLEASE SIR HELP ME
