How to use Matrix3D.setToRotationTo? I get an 'attribute error'
I want to create a body on the XY plane and then transform it to final position.
For the rotation I tried to use Matrix3D.setToRotationTo(from, to) method. But I get 'Attribute Error'. Why?
How to use this method?
I guess it creates a transformation matrix from these two vectors. How is the rotation point defined.
I also tried to use  Matrix3D.setToAlignCoordinateSystem. But it also raises an error.
xapo
Code snippet from my test program.  Running code is in attached zip file.
        transform = adsk.core.Matrix3D.create()
        from_vector = adsk.core.Vector3D.create(0, 0, 1)
        to_vector = adsk.core.Vector3D.create(1, 1, 1)
        transform.setToRotationTo(from_vector, to_vector)
moveFeats = rootComp.features.moveFeatures moveFeatureInput = moveFeats.createInput(bodies, transform) moveFeats.add(moveFeatureInput)
JesusFreke
You want "setToRotateTo", not "setToRotationTo" 🙂
OMG, you are right, what a stupid mistake!
thank you!
and I learned also that:
'to' vector must be a unit vector otherwise it scales the object
x.
