How to use isOrientationAlognPath properly?
tmelloCKF6Z
tmelloCKF6Z
I am having trouble using the python API to set the Orientation of a path pattern to "Path Direction".
I have a body that I am patterning along a path (3d curve).  The body should be oriented with the path - not the default "Identical" option.
I have tried using both the PathPatternFeatureInput and the pathPatternFeaturesInput.  The feature input I can't seem to create properly (object and attributes appear to be set but the path feature is not made), while the features input will create a feature but won't have the proper orientation as specified.
I believe I've seen some feature options access through the UI API, is there a solution using the ui feature dialog?
Any guidance would be helpful!
The code below yields an error that the "path_input" is not a PathPatternFeatureInput, yet the path_input classType is a PathPaternFeatureInput...
path_input = adsk.fusion.PathPatternFeatureInput
path_input.inputEntites = inputEntites
path_input.path=path
path_input.quantity = quantity
path_input.distance = patternDistance
path_input.patterDistanceType = adsk.fusion.PatternDistanceType.ExtentPatternDistanceType
path_input.isOrientationAlongPath = True
pathPattern = root.features.pathPatternFeatures
pathFeature = pathPattern.add(path_input)
I've also tried using a pathPatternInput which creates the feature but does not set the orientation as I would expect.
# Create the input for path pattern
pathPatterns = root.features.pathPatternFeatures
pathPatternInput = pathPatterns.createInput(inputEntites, path, quantity, patternDistance, adsk.fusion.PatternDistanceType.ExtentPatternDistanceType)
#set orientation
pathPatternInput.isOrientationAlongPath = True
# Create the path pattern
pathFeature = pathPatterns.add(pathPatternInput)
kandennti
Hi @tmelloCKF6Z .
I don't think you can create an instance with this way of writing.
Instances can be created using the method described at the bottom of the document.
As for the isOrientationAlognPath property, I tried it with the following script and attached data.
#Fusion360API Python script
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        des :adsk.fusion.Design = _app.activeProduct
        root :adsk.fusion.Component = des.rootComponent
        # select body
        msg :str = 'SelectBody'
        selFiltter :str = 'Bodies'
        sel :adsk.core.Selection = selectEnt(msg ,selFiltter)
        if not sel: return
        body :adsk.fusion.BRepBodies = sel.entity
        # select path
        msg :str = 'Select Sketch Curve'
        selFiltter :str = 'SketchCurves'
        if not sel: return
        sketchCurve :adsk.fusion.SketchCurve = sel.entity
        # Create input entities for rectangular pattern
        inputEntites = adsk.core.ObjectCollection.create()
        inputEntites.add(body)
        # Create path for path pattern
        features :adsk.fusion.Features = root.features
        path = features.createPath(sketchCurve)
        # Quantity and distance
        quantity = adsk.core.ValueInput.createByString('10')
        patternDistance = adsk.core.ValueInput.createByString('50 cm')
        pathPatterns = features.pathPatternFeatures
            inputEntites,
            path,
            quantity,
            patternDistance,
        # isOrientationAlongPath = True
        pathFeature.name = 'True'
        # isOrientationAlongPath = False
        pathPatternInput.isOrientationAlongPath = False
        pathFeature.name = 'False'
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def selectEnt(
    msg :str,
    filtterStr :str
    ) -> adsk.core.Selection :
    try:
        sel = _ui.selectEntity(msg, filtterStr)
        return sel
    except:
        return None
The blue color is "isOrientationAlognPath = False".
I think it works fine.
tmelloCKF6Z
I appreciate your follow up.
The second set of code I posted seems identical to what you did, yet mine isn't working!  I re-ran it today and it worked!
Thank you for posting the proper use of this function!  It was very helpful!
