Hi @Mathias_RAW .
API will be updated together.
Here is a sample using maximum/minimumValue.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
'id': 'kantoku_test',
'name': 'test',
'tooltip': 'test'
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.CommandCreatedEventArgs):
core.Application.get().log(args.firingEvent.name)
try:
global _handlers
cmd: core.Command = core.Command.cast(args.command)
inputs: core.CommandInputs = cmd.commandInputs
onDestroy = MyCommandDestroyHandler()
cmd.destroy.add(onDestroy)
_handlers.append(onDestroy)
valueIpt: core.ValueCommandInput = inputs.addValueInput(
'valueIptId',
'1mm - 3mm',
'mm',
core.ValueInput.createByReal(0.2)
valueIpt.minimumValue = 0.1
valueIpt.maximumValue = 0.3
except:
_ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyCommandDestroyHandler(core.CommandEventHandler):
def __init__(self):
super().__init__()
def notify(self, args: core.CommandEventArgs):
adsk.terminate()
def run(context):
try:
global _app, _ui
_app = core.Application.get()
_ui = _app.userInterface
cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
CMD_INFO['id']
if not cmdDef:
cmdDef = _ui.commandDefinitions.addButtonDefinition(
CMD_INFO['id'],
CMD_INFO['name'],
CMD_INFO['tooltip']
global _handlers
onCommandCreated = MyCommandCreatedHandler()
cmdDef.commandCreated.add(onCommandCreated)
_handlers.append(onCommandCreated)
cmdDef.execute()
adsk.autoTerminate(False)
except:
if _ui:
The valid range is set to 1-3mm, so if the value is out of the range, the text will be red and the OK button will be grayed out.
