How to update the Fusion 360 API
Mathias_RAW
Mathias_RAW
Hi everyone,
Is the Fusion 360 app API updated automatically?
I'm writing a python add-in, and I want to use some new properties introduced in the November 2022 update - however they do not seem to be included in core.py (the API).
I'm specifically interested in the maximum/minimumValue properties for ValueCommandInput's.
Best Regards,
Mathias Thor
kandennti
Hi @Mathias_RAW .
API will be updated together.
Here is a sample using maximum/minimumValue.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
    'id': 'kantoku_test',
    'name': 'test',
    'tooltip': 'test'
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        core.Application.get().log(args.firingEvent.name)
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            inputs: core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            valueIpt: core.ValueCommandInput = inputs.addValueInput(
                'valueIptId',
                '1mm - 3mm',
                'mm',
                core.ValueInput.createByReal(0.2)
            valueIpt.minimumValue = 0.1
            valueIpt.maximumValue = 0.3
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO['id']
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO['id'],
                CMD_INFO['name'],
                CMD_INFO['tooltip']
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
The valid range is set to 1-3mm, so if the value is out of the range, the text will be red and the OK button will be grayed out.
Mathias_RAW
Hi @kandennti
Thanks for your detailed answer!
Somehow my Fusion 360 was not up to date...
Best Regards,
Mathias Thor
kandennti
@Mathias_RAW .
Last year there was a version where "LiveUpdate" didn't work.
At that time, I had to manually re-install the Fusion360 overwrite to bring the version up to date.
The latest version now is ver 2.0.15050.
