How to swap a sketch from a component to other
en9y37
en9y37
Hi there.
I'm looking for a method to move a sketch from one component to other one via API. The result expected is the same as if drag it manually in the user interface like this:
BEFORE:
AFTER:
Any idea about this?
Thanks in advance
kandennti
Hi @en9y37 .
I could not find that function in the API.
Not in a good way, but it was possible using text commands.
The following sample creates a new occurrence, sketches and extrudes it.
Then move the sketch to the root component.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        # create test data
        app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        create_test_data()
        # select sketch
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        fromOcc: adsk.fusion.Occurrence = root.occurrences[-1]
        nativeSketch: adsk.fusion.Sketch = fromOcc.component.sketches[-1]
        targetSketch: adsk.fusion.Sketch = nativeSketch.createForAssemblyContext(fromOcc)
        sels: adsk.core.Selections = ui.activeSelections
        sels.clear()
        sels.add(targetSketch)
        dump_sketch_info(targetSketch, 'before')
        app.activeViewport.fit()
        ui.messageBox('before')
        # exec cut command
        app.executeTextCommand(u'Commands.Start CutCommand')
        # select root component
        sels.clear()
        sels.add(root)
        # exec paste command
        app.executeTextCommand(u'Commands.Start PasteCommand')
        dump_sketch_info(targetSketch, 'after')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def dump_sketch_info(skt: adsk.fusion.Sketch, msg: str):
    msgLst = [
        f'**{msg}**',
        f'Component Name : {skt.parentComponent.name}',
    try:
        msgLst.append(f'entityToken : {skt.entityToken}')
    except:
        msgLst.append( 'error')
    adsk.core.Application.get().log('\n'.join(msgLst))
def create_test_data():
    occ: adsk.fusion.Occurrence = root.occurrences.addNewComponent(
        adsk.core.Matrix3D.create()
    comp: adsk.fusion.Component = occ.component
    skt: adsk.fusion.Sketch = comp.sketches.add(comp.xYConstructionPlane)
    skt.sketchCurves.sketchCircles.addByCenterRadius(
        adsk.core.Point3D.create(0,1,2),
        0.5
    extFeats: adsk.fusion.ExtrudeFeatures = comp.features.extrudeFeatures
    extFeats.addSimple(
        skt.profiles[0],
        adsk.core.ValueInput.createByReal(5),
        adsk.fusion.FeatureOperations.NewBodyFeatureOperation
After executing the script, you can confirm that it has been moved by operating undo.
However, since the original sketch object's entityToken property, etc. cannot be obtained, there may be some problems later on.
en9y37
Hi @kandennti
Thanks for your response. I've given a try and works properly. Nice work around!!!
BrianEkins
Unfortunately, the API does not currently support the ability to move a sketch from one component to another.
Brian Ekins
