How to save as USD file with API
ruk.shan
Observer Observer
ruk.shan
Observer
Observer
There is a way to export STL files with API "utils.export_stl(app, save_dir)"  . Is there a similar way to save as USD files ?
Rushikesh.kadam
@ruk.shan Here is a link that shows how to export to USD format using API.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-78B91813-88C3-4777-AEC2-19F5FB438ED2
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
ruk.shan
Observer
Observer
Great. Thank you so much
Jorge_Jaramillo
With this function you can export the currently open design:
def exportToUSD():
    try:
        global _app, _ui
        exportMgr = adsk.fusion.ExportManager.cast(_app.activeProduct.exportManager)
        usdOptions = exportMgr.createUSDExportOptions(tempfile.gettempdir() + "/test.usd")
        return(f'export to USD was: {exportMgr.execute(usdOptions)}')
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
        return(f'error exporting to {tempfile.gettempdir() + "/test.usd"}')
Jorge
hclmed
Thanks for this example. Is there a method that also includes joints, since those are supported by USD?
