How to print a image
nubrandao
nubrandao
Hi, is possible to build a script were i can print a image of my part for manufacture use?
I use setup sheet for CAM, but imagem is top small and is on a ISO perspective.
I want to Run a script that works like CTRL+p and opens UP the image were i can copy to my setup sheet.
And do this with my current view
rohit_maneYV8C9
Hello @nubrandao ,
You can refer to this example to capture the screen. It uses the Viewport.saveAsImageFile method. However, if you need more control over specific attributes, you can use the Viewport.saveAsImageFileWithOptions method instead. For instance, it allows you to set properties such as SaveImageFileOptions.isBackgroundTransparent.
nubrandao
I dont understand pyton, i know to create script
How should look like the script if i want to apply Viewport.saveAsImageFileWithOptions method instead. For instance, it allows you to set properties such as SaveImageFileOptions.isBackgroundTransparent.
rohit_maneYV8C9
Similarly as shown in example, This way you can use those saveAsImageFileWithOptions method.
SaveImageFileOptions = adsk.core.SaveImageFileOptions.create(filePath)
SaveImageFileOptions.isBackgroundTransparent = True
app.activeViewport.saveAsImageFileWithOptions(
            SaveImageFileOptions)
