How to limit add-in functionality in Fusion360
gear2nd.droid
gear2nd.droid
I believe that the Fusion360 add-in allows you to use some of the features in the trial version even at the non-purchase stage and allows you to perform all of the features once purchased.
Could you please tell me how to implement this?
BrianEkins
There's nothing in the Fusion API to support this. It's all done by the add-in, usually using some type of web API to query and determine what type of license is being used and then behaving appropriately for that type of license. If you deliver your app using the Autodesk App Store, you can use it to determine if the current user has purchased the add-in or not. The App Store has an web API that supports that, but then once you have that information it's still up to you to use that information to have your add-in behave appropriately.
Another option is to do the licensing yourself. There are commercial licensing applications you can use or you can write your own.
But, to reiterate, this is all independent of Fusion and you won't find anything in the API to help except the ability to get information about the current user to know who is using your add-in.
Brian Ekins
gear2nd.droid
Thank you for your response, where can I find the AppStore WebAPI documentation? Or could you please tell me how to look it up?
BrianEkins
Here's a link to the documentation. I assume this is the latest version.
https://damassets.autodesk.net/content/dam/autodesk/www/adn/pdf/entitlement-api-for-desktop-apps.pdf
Brian Ekins
gear2nd.droid
thank you. I'll try testing it.
