How to hide value input on start of command?
Six1Seven1
Six1Seven1
I am trying to hide my value input via the inputchangedevent handler, but it is not working correctly. When opening the addin dialogue, the "hidden" value input is VISIBLE. And i want it not visible unless my boolean value is TRUE.
Until the user click the button, then it will show up. Otherwise, it will stay hidden.
Any way I configure the code, this does not work. Its always visible from the start. It will hide when I click it, sometimes have to click TWICE.
Creating the value input:
fillet_cb = inputs.addBoolValueInput('fillet_cb','Add Corner Fillets', False,'./Resources/Image Input/Fillets', False)
Input Changed Handler:
class inputChangedEvent(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            eventArgs = adsk.core.InputChangedEventArgs.cast(args)
            changedInput = eventArgs.input
            fillet_in = None
            if changedInput.id == 'fillet_cb':
                inputs = eventArgs.firingEvent.sender.commandInputs
                fillet_in = inputs.itemById('fillet_in')
            # Change the visibility of the scale value input.
            if fillet_in:
                if changedInput.value == True:
                    fillet_in.isVisible = True
                else:
                    fillet_in.isVisible = False
        except:
            if ui:
                ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Regardless of changing the visibility to false and alternating the input command "initial value" , no configuration works. Button still visible on start of addin.
Thank you!
marshaltu
You may have to give initial value "True" when create "fillet_cb". It meant you intend to show "fillet_in" command input by default. Otherwise you should hide "fillet_in" right away after it is created.
fillet_cb = inputs.addBoolValueInput('fillet_cb','Add Corner Fillets', False,'', True)
Marshal
Marshal Tu
Fusion Developer
Six1Seven1
Marshal,
Like I said, nothing works correctly. I have changed the initial value and the visibility logic over and over and the result is nearly the same. No hiding. This may be a bug.
But see my code
import adsk.core, adsk.fusion, adsk.cam, traceback
# Global list to keep all event handlers in scope.
# This is only needed with Python.
handlers = []
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Get the CommandDefinitions collection.
        cmdDefs = ui.commandDefinitions
        # Create a button command definition.
        buttonSample = cmdDefs.addButtonDefinition('MainButton','Plate Generator', 'An Add-in which generates a solid rectangle and applies holes or slots equidistant from part center.','./Resources/Main Icons')
        # Connect to the command created event.
        MainButtonEvent = SampleCommandCreatedEventHandler()
        buttonSample.commandCreated.add(MainButtonEvent)
        handlers.append(MainButtonEvent)
        # Get the ADD-INS panel in the model workspace.
        addInsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        # Add the button to the bottom of the panel.
        buttonControl = addInsPanel.controls.addCommand(buttonSample)
        buttonControl.isPromoted = True
    except:
        if ui:
# Event handler for the commandCreated event.
class SampleCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
            # Get the command
            cmd = eventArgs.command
            cmd.okButtonText = ("Generate") #text in "OK" button
            # Get the CommandInputs collection to create new command inputs.
            inputs = cmd.commandInputs
            #Add image input
            imageinput1 = inputs.addImageCommandInput('imageinput1','Diagram:','./Resources/Image Input/Diagram/diagram.png')
            # Create the value inputs
            length_in = inputs.addValueInput('length_in', 'Length','', adsk.core.ValueInput.createByReal(3))
            width_in = inputs.addValueInput('width_in','Width','',adsk.core.ValueInput.createByReal(2))
            thick_in = inputs.addValueInput('thick_in','Thickness','',adsk.core.ValueInput.createByReal(1))
            hole_cb = inputs.addBoolValueInput('hole_cb','Add Hole Pattern', True,'', True)
            hole_dia = inputs.addValueInput('hole_dia','Hole Diameter','',adsk.core.ValueInput.createByReal(0))
            hole_spcX = inputs.addValueInput('hole_spcX','Hole Spacing in X','',adsk.core.ValueInput.createByReal(0))
            hole_spcY = inputs.addValueInput('hole_spcY','Hole Spacing in Y','',adsk.core.ValueInput.createByReal(0))
            fillet_cb = inputs.addBoolValueInput('fillet_cb','Add Corner Fillets', False,'./Resources/Image Input/Fillets', True)
            fillet_in = inputs.addValueInput('fillet_in','Fillet Radius','',adsk.core.ValueInput.createByReal(0))
            qty = inputs.addDropDownCommandInput('qty','Quantity',1)
            list_items1 = qty.listItems
            list_items1.add('2',True,'')
            list_items1.add('4',False,'')
            inputChanged = inputChangedEvent()
            cmd.inputChanged.add(inputChanged)
            handlers.append(inputChanged)
            onExecute = SampleCommandExecuteHandler()
            cmd.execute.add(onExecute)
            handlers.append(onExecute)
#            onExecutePreview = MyExecutePreviewHandler()
#            cmd.executePreview.add(onExecutePreview)
#            handlers.append(onExecutePreview)
        except:
            if ui:
# Event handler for the execute event.
class SampleCommandExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.CommandEventArgs.cast(args)
            # Code to react to the event.
            ui.messageBox('In command execute event handler.')
            # Get the values from the command inputs.
            inputs = eventArgs.command.commandInputs
            length = inputs.itemById('length_in').value
            width = inputs.itemById('width_in').value
            thickness = inputs.itemById('thick_in').value
            fillet = inputs.itemById('fillet_in').value
            filletcb = inputs.itemById('fillet_cb').value
            hole_dia = inputs.itemById('hole_dia').value
            hole_spcX = inputs.itemById('hole_spcX').value
            hole_spcY = inputs.itemById('hole_spcY').value
            holecb = inputs.itemById('hole_cb').value
        except:
            if ui:
    def __init__(self):
        super().__init__()
        try:
            fillet_in = None
            if fillet_in:
                else:
        except:
            if ui:
def stop(context):
    try:
        #Delete Button Def
        buttonSample = ui.commandDefinitions.itemById('MainButton')
        if buttonSample:
            buttonSample.deleteMe()
        #Delete Button Control
        addinsPanel = ui.allToolbarPanels.itemById('SolidScriptsAddinsPanel')
        cntrl = addinsPanel.controls.itemById('MainButton')
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
ekinsb
Here's a slight variation of your add-in that seems to be working as expected.  The main thing I did to address your question is that I set the isVisible property of the ValueCommandInput to False right after it's created.  That stops it from being displayed when the dialog first appears.  That was the main problem.  I also fixed a couple of issues where you defining the ui variable so it was failing when trying to display some errors (because I didn't have the resource files).  Another change that I made that you might want to change back is that I changed one of the arguments when creating the bool value input to be a check box.  Because it has an image assigned to it, it still looks like a button but now it behaves like a check box in that it has two states, pressed and unpressed, which I think is what you might want.  A typical button doesn't really have states but is just used to notify you want it's clicked.
handlers = []
def run(context):
    ui = None
    try:
    except:
        if ui:
    def __init__(self):
        super().__init__()
        try:
            # Get the command
            #Add image input
            fillet_cb = inputs.addBoolValueInput('fillet_cb','Add Corner Fillets', True,'./Resources/Image Input/Fillets', False)
        except:
            if ui:
    def __init__(self):
        super().__init__()
        try:
        except:
            if ui:
    def __init__(self):
        super().__init__()
        try:
            fillet_in = None
                if fillet_in:
                    else:
        except:
            if ui:
def stop(context):
    try:
        #Delete Button Def
        if buttonSample:
        if cntrl:
            cntrl.deleteMe()
    except:
        if ui:
Brian Ekins
Mod the Machine blog
Six1Seven1
Ok Brian allow me to check this.
Thank you for your time,
Ill report back
Six1Seven1
Brian,
It worked!  What worked was setting the .isVisible property to FALSE. Any other solution did not work. Thank you for your time. I appreciate it.
Regards
