How to get unit of Physical Properties like mass, area, volume, etc
pts_user1
pts_user1
Tried to fetch the unit of mass, volume, etc through API but no such method was found to get units of Physical Properties. For example, if a component mass is in ounce mass in Fusion Environment but when getting the same value through API it shows in gms (if converted and checked). So just want to know is there any way to know the unit of these properties. If yes it would be great
tykapl.breuil
The units are written in the documentation (here for example), I don't think there is a way to fetch nor change that unit (as it would cause compatibility issues between machines) but as there isn't a ton of them I think you can manage just storing what the unit is and converting them manually/through the unitManager.
