- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been hanging out for the new SketchFixedSplines.addByNurbsCurve method all year, and it's looking tantalizingly close!! It says
Introduced in version October 2020
But my Fusion360 version says
2.0.9011
So I assume that's September? How do I get October??
I did try to see if it works - but no luck:
I'm hoping to do stuff like this:-
(adapted from this awesome link)
Here's my code:-
#Author-Chris Drake
#Description-Testing if the API can create control splines
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
ui.messageBox('Hello script')
design = app.activeProduct
rootComp = design.rootComponent
sketches = rootComp.sketches
sketch = sketches.add(rootComp.xYConstructionPlane)
sketchCurves = sketch.sketchCurves
knots = [ 0,0,0,0, 1,1,1,1 ]
degree = 3
P0 = adsk.core.Point3D.create(0, 0, 0)
P1 = adsk.core.Point3D.create(1, 0, 0)
P2 = adsk.core.Point3D.create(1, 1, 0)
P3 = adsk.core.Point3D.create(0, 1, 0)
controlPoints = [ P0,P1,P2,P3 ]
#sketchCurves.sketchFixedSplines.addByNurbsCurve( adsk.core.NurbsCurve3D.createNonRational(controlPoints, degree, knots, False )) # Fails 2020-10-18
sketchCurves.sketchFittedSplines.addByNurbsCurve( adsk.core.NurbsCurve3D.createNonRational(controlPoints, degree, knots, False )) # Semi-works (breaks if user edits)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
