How to get the final value of CAMParameter
kandennti
Mentor Mentor
kandennti
Hi there,
I'm working on a test script for CAM, but there were some parts that were unclear to me.
I'm testing it with the sample data here.
I have created a script that looks like this.
import adsk.core, adsk.fusion, adsk.cam, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        doc = _app.activeDocument
        products = doc.products
        product = products.itemByProductType('CAMProductType')
        cam = adsk.cam.CAM.cast(product)
        ope :adsk.cam.Operation = cam.allOperations[0]
        stayDownDistance :adsk.cam.CAMParameter = ope.parameters.itemByName('stayDownDistance')
        print('title:{}\nname:{}\nexpression:{}'.format(
            stayDownDistance.title,
            stayDownDistance.name,
            stayDownDistance.expression
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I would like to get the "Maximum Stay-Down Distance" value for the first operation.
The CAMParameter object has an "expression" but no property that indicates the final value, such as "value".
"10 in" not found.
The only way I can think of at the moment is to parse "expression" and get the corresponding values from all the parameters and calculate them...
Is there an easy way to get the final value?
kandennti
I'm developing an add-ins that uses the recently introduced ActiveSelectionEvent and allows you to check configuration information without opening a dialog.
We plan to release it on github in the future.
However, due to the above problems, it is far from what we want.
If you have some information, I would appreciate it.
jsormaz
I am facing the same issue.
Is there still no way to directly get the value of a CAMParameter?
Instagram:
@sonsofsormaz
