how to get the depth of a hole from a from model parameters?
david.lopez7E84R
david.lopez7E84R
I can get counterbore hole depth and diameter to include the hole's diameter using:
hole_dia = adsk.fusion.Design.cast(self.app.activeProduct).features.holeFeatures.item(0).holeDiameter.expression
cb_depth = adsk.fusion.Design.cast(self.app.activeProduct).features.holeFeatures.item(0).counterboreDepth.expression
cs_dia = adsk.fusion.Design.cast(self.app.activeProduct).features.holeFeatures.item(0).countersinkDiameter.expression
I need to figure out how to consistently get the depth of the hole because that measurement is not readily available.
My issue isn't so much in getting the depth of the hole, I can see the values I need in a number of ways, the problem is mapping the value in a consistent way that lets me get the value the same way in my script to automate the identification of feature in a part designed in fusion. For example, I can get the depth of the hole in a series of timeline values returned in the order the parameter and its name were drawn:
param_name = adsk.fusion.Design.cast(self.app.activeProduct).allParameters.item(0).name
The problem is that the name parameter is not the name field available the way item(0).name is available for Hole1. Please see this picture:
the HoleDepth ParameterName is what Im after, I want to iterate through those names with a for loop at the same time I am iterating through the values I am identifying for the other dimensions so I can map the correct dimensions together.
any other way to get the length of the hole?
kandennti
Hi @david.lopez7E84R .
How about this?
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        for holeFeat in root.features.holeFeatures:
            msg = f'{holeFeat.name} - {holeFeat.extentDefinition.distance.expression}'
            app.log(msg)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
david.lopez7E84R
wow
thats the solution I was expecting however, it wasn't showing up in the visual studio drop down as an available option and I assumed there was no distance measurement and expression values
I only tried it because you proposed it as a solution; I am relying too much on the suggested methods!!
Maybe we found a bug to report?
BrianEkins
What you're seeing isn't a bug. The depth of a hole can be defined in several different ways; a specific depth, through all, to a face, etc. The HoleFeature has the extentDefinition property that returns an ExtentDefinition object. The ExtentDefinition object is the base class and what's really returned is a DistanceExtentDefinition, ToEntityExtentDefinition, or ThroughAllExtentDefinition. What you get back will be determined at runtime based on how the hole was created. In your case, you only want to handle if a DistanceExtentDefinition object is returned because it's the only type that has the distance property.
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
