How to get the cam template libraries
maurizio_manzi
maurizio_manzi
How to get the cam template libraries: folder and templates in any folder ?
I can't found any example, that works..
Best regards
Maurizio
boopathi.sivakumar
Hi @maurizio_manzi
You can refer this example
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-{3C372103-F3EF-4C85-9849-934F112D0A50}https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-{3C372103-F3EF-4C85-9849-934F112D0A50}
here
def getTemplateFromLibrary(templateLibrary: adsk.cam.CAMTemplateLibrary, libLocation: adsk.cam.LibraryLocations, folderName: str, templateNameSubstring: str):
    libraryURL = templateLibrary.urlByLocation(libLocation)
    templates = None
    if folderName == "":
        templates = templateLibrary.childTemplates(libraryURL)
    else:
        childFolders = templateLibrary.childFolderURLs(libraryURL)
        pickedFolderURL = None
        for folderURL in childFolders:
            if folderURL.leafName.lower() == folderName.lower():
                pickedFolderURL = folderURL
                break
        templates = templateLibrary.childTemplates(pickedFolderURL)
    pickedTemplate = None
    for template in templates:
        lowerCaseName: str = template.name.lower()
        if lowerCaseName.find(templateNameSubstring.lower()) != -1:
            pickedTemplate = template
            break
    return pickedTemplate
Boopathi Sivakumar
Senior Technology Consultant
maurizio_manzi
Thank you very much.
It is also possible to get a list of the operations, if the template is a template-group (see pic) ?
Best regards
Maurizio
boopathi.sivakumar
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-0586D2B2-0683-462B-B3B8-B1E387CEC0F4
I think should be possible when you have a template then you can get the operations by template.operations
and its a list you should be able to itereate over to get the name or other things
Boopathi Sivakumar
maurizio_manzi
yes, I know the template.operations, but an iteration is not possible and it have no .item() parameter.
Only you can do with template.operations is to get the count of it..
jeff.pek
I'm not sure why it was done this way, but operations has a "get" method that takes a 0-based index, instead of the usual "item" or "itemAt" method. These return a CAMTemplateOperationInput object.
Jeff
maurizio_manzi
Thnak you very much
