How to get sketch spline points in python?
eric
eric
I'm trying to figure out how to get a sketched splines points in python.
I started with the intersetcts example and am able to get to a point where I think I have a selected item in variable geom...
            inputs = command.commandInputs
            input0 = inputs[0];
            sel0 = input0.selection(0);
            entityOne = sel0.entity
              if isinstance(entityOne,adsk.fusion.SketchCurve):
                geom=entityOne.worldGeometry
                ui.messageBox('isacurve')
So here I have geom, but how to get the splines points?
Is there a programming API I can get access too which would explain all the member functions and variables of the adsk class?
marshaltu
The following codes demo how to get points from spline.
In addition, you should be able to get API help from the web page http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A92A4B10-3781-4925-94C6-47DA85A4F65A .
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        spline = adsk.fusion.SketchFittedSpline.cast(ui.activeSelections.item(0).entity)
        if spline:
            result = ''
            for sketchpoint in spline.fitPoints:
                point = sketchpoint.geometry
                result += '{}, {}, {}\n'.format(point.x, point.y, point.z)
            ui.messageBox('Spline points: {}\n {}'.format(spline.fitPoints.count, result))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion Developer
jmpframce
ok to import  in fusion  like a script?
