How to get screenshot of scene by API
I would like to make an add-in for Fusion 360 which should save screenshot of scene/workplace periodically. The period of time will be defined by user. It will help to track time and build timeline of work. The saved images (screenshots) could be used to make a video and publish somewhere on web.
So is there any api method to get image of scene or any way to do it?
frankzhang
You may want to try the tool called screencast, check out here:
http://www.autodesk.com/products/screencast/overview
liujac
You may use Viewport.saveAsImageFile.
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        app.activeViewport.saveAsImageFile("c:/box.jpg", 400, 300);
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Jack
Thank you for reply, but I don't need to make screencast but I want make a some kind timetracker and timeline of modeling for freelancers/employees and employers.
In the market there are many time trackers software but they all require to start, pause, suspend and stop when you work, the add-in I want to make should give a free of these actions, you just work and the plugin will calculate work time and even more it will make a sequences/video how the modeling process was done, for example every 2 seconds it will save screenshots if there is activity and it can tell how many real time spend on modeling and you can watch it as a video (outside of the fusion of course).
Thank you! I will cehck it!
