How to extrude sketch text using API
My intent is to extrude sketch text.  But when I add SketchText object to the new sketch I always get empty sketch.profiles collection.  How can I provide a valid text-based profile to create ExtrudeFeatureInput object?
Fusion API Help indicates that Profiles class “also provides some additional utility functions to create open profiles and text based profiles that can be used as input for various features.”  Where these functions are described?
Any code sample would be greatly appreciated.
Here is my test code that creates sketch text:
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        design = app.activeProduct
        # Get the root component of the active design.
        rootComp = design.rootComponent
        # Create a new sketch on the xy plane.
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        # Get sketch texts
        sketchTexts = sketch.sketchTexts
        # Create sketch text input
        point = adsk.core.Point3D.create(1.0, 1.0, 1.0)
        sketchTextInput = sketchTexts.createInput('example', 1.0, point)
        sketchText = sketchTexts.add(sketchTextInput)
        m = sketch.sketchTexts.count
        n = sketch.profiles.count
        ui.messageBox("sketchTexts.count:  %i  \nprofiles .count: %i" % (m, n))
#    # Create an extrusion input
#    extrudes = rootComp.features.extrudeFeatures
#    extInput = extrudes.createInput(profile, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
#    distance = adsk.core.ValueInput.createByReal(0.1)
#    extInput.setDistanceExtent(False, distance)
#    extInput.isSolid = True
#    # Create the extrusion
#    ext = extrudes.add(extInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
thanks
marshaltu
You can create an extrude by sketch text directly instead of profile. Please refer to the following codes:
def run(context):
    ui = None
    try:
        # Get sketch texts
        extInput = extrudes.createInput(sketchText, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    except:
        if ui:
Marshal
Marshal Tu
Fusion Developer
Great.  Thanks!
