how to draw polyline and transform lines. I want to draw Hexagon,
nkc.mech
nkc.mech
I want to draw Hexagon, & follow step:
1. draw line
2. Copy line
3. translate line by line length
4. rotate by 60 deg
kandennti
Hi @nkc.mech .
Why don't you calculate the vertex coordinates of the polygon and draw a line between the two points?
#Fusion360API Python Script
import adsk.core, adsk.fusion, traceback
import math
# Circumscribed circle center XY - unit Cm
_center = [1.0, 2.0]
# Circumscribed circle radius - unit Cm
_radius = 5.0
# Vertex count
_vertex_count = 6
# Vertex start angle - unit deg
_ang = 30
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        # get Vertexs
        pnts = getVertexPoints()
        # sketch
        skt = root.sketches.add(root.xYConstructionPlane)
        # draw Polyline
        drawPolyline(skt, pnts)
        # finish
        ui.messageBox('done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def drawPolyline(
    skt :adsk.fusion.Sketch,
    pnts :list):
    count = len(pnts)
    pnts.append(pnts[0])
    lines = skt.sketchCurves.sketchLines
    skt.isComputeDeferred = True
    [lines.addByTwoPoints(pnts[i], pnts[i + 1]) for i in range(count)]
    skt.isComputeDeferred = False
def getVertexPoints() -> adsk.core.Point3D:
    global _center, _radius, _vertex_count, _ang
    rad = math.radians(_ang)
    unit_rad = math.pi * 2 / _vertex_count
    rads = [rad + (unit_rad * idx) for idx in range(1, _vertex_count + 1)]
    pnt3D = adsk.core.Point3D
    pnts = [pnt3D.create(math.cos(rad) * _radius, math.sin(rad) * _radius, 0)
        for rad in rads]
    targetPnt = pnt3D.create(_center[0], _center[1], 0)
    vec = pnt3D.create(0,0,0).vectorTo(targetPnt)
    [pnt.translateBy(vec) for pnt in pnts]
    return pnts
