how to dimension sketch elements programmatically?
AagAag
AagAag
I am starting to play around with the python API. I have a small script that draws a bunch of circles. Might a good soul explain to me how I should dimension said circles programmatically, so that they will be fully constrained?
See:
import adsk.core, adsk.fusion, adsk.cam, traceback, math
def run(context😞
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = app.activeProduct
        unitsMgr = design.fusionUnitsManager
        unitsMgr.distanceDisplayUnits = adsk.fusion.DistanceUnits.MillimeterDistanceUnits
        # Get the root component of the active design.
        rootComp = design.rootComponent
        # Create a new sketch on the xy plane.
        sketches = rootComp.sketches
        xyPlane = rootComp.xYConstructionPlane
        sketch = sketches.add(xyPlane)
        circles = sketch.sketchCurves.sketchCircles
        diameterFirst = 1
        circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, diameterFirst, 0), diameterFirst)
        yRange=range(0,100,10)
        for yn in yRange:
            xRange=range(0,9,1
            x=0
            y = yn * diameterFirst/9
            circle1 = circles.addByCenterRadius(adsk.core.Point3D.create(0, y, 0), diameterFirst)
            for n in xRange:
                diameterNext=diameterFirst + .1
                x=x+diameterFirst+diameterNext+0.2
                pointNext = adsk.core.Point3D.create(x, y, 0)
                circleInner = circles.addByCenterRadius(pointNext, diameterNext)
                diameterFirst=diameterNext
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
BrianEkins
You use methods on the SketchDimensions collection, which you obtain from the Sketch object.  I modified your code to add this.  When placing a dimension, you need to specify the position of the text.  I tried using the center of the circle but for some reason, Fusion doesn't allow this so I offset it slightly to not be at the center.  I also added the use of the isComputeDeferred property of the sketch.  With this, the processing when from about 25 seconds to 2 seconds.
def run(context):
    ui = None
    try:
        dims = adsk.fusion.SketchDimensions.cast(sketch.sketchDimensions)
        sketch.isComputeDeferred = True
        diameterFirst = 1
        center =  circle1.centerSketchPoint.geometry
        center.x += 0.01
        center.y += 0.01
        center.z += 0.01
        dims.addRadialDimension(circle1, center)
        for yn in yRange:
            xRange=range(0,9,1)
            x=0
            center.x += 0.01
            center.y += 0.01
            center.z += 0.01
            for n in xRange:
                center =  circleInner.centerSketchPoint.geometry
                center.x += 0.01
                center.y += 0.01
                center.z += 0.01
                dims.addRadialDimension(circleInner, center)
        sketch.isComputeDeferred = False
    except:
        if ui:
Brian Ekins
Inventor and Fusion 360 API Expert
Website/Blog: https://EkinsSolutions.com
AagAag
thank you for your invaluable help, which is greatly appreciated. I hope that I will not abuse your kindness by asking a further related question: how do I programmatically dimension the distance of each circle in the XY space, e.g. by specifying the distance to the origin, so that the sketch will be fully constrained? Thanks in advance!
kandennti
Hi @AagAag .
Because it looks interesting, I tried it.
def run(context):
    ui = None
    try:
        # extension method
        adsk.fusion.SketchCircle.setDimension = setDimension
        diameterFirst = 1
        center.x += 0.01
        center.y += 0.01
        center.z += 0.01
        circle1.setDimension()
        for yn in yRange:
            xRange=range(0,9,1)
            x=0
            center.x += 0.01
            center.y += 0.01
            center.z += 0.01
            for n in xRange:
                center.x += 0.01
                center.y += 0.01
                center.z += 0.01
                circleInner.setDimension()
    except:
        if ui:
def setDimension(
    self :adsk.fusion.SketchCircle):
    skt :adsk.fusion.Sketch = self.parentSketch
    ori :adsk.fusion.SketchPoint = skt.sketchPoints.item(0)
    ctr :adsk.fusion.SketchPoint = self.centerSketchPoint
    ary = [(o + c) * 0.5 for (o, c) in
        zip(ori.geometry.asArray(), ctr.geometry.asArray())]
    mid :adsk.core.Point3D = ori.geometry.copy()
    mid.setWithArray(ary)
    dims :adsk.fusion.SketchDimensions = skt.sketchDimensions
    h = adsk.fusion.DimensionOrientations.HorizontalDimensionOrientation
    v = adsk.fusion.DimensionOrientations.VerticalDimensionOrientation
    dims.addDistanceDimension(ori, ctr, h, mid, True)
    dims.addDistanceDimension(ori, ctr, v, mid, True)
BrianEkins
If your end goal is to create a fully constrained sketch, I would recommend just "fixing" the circle.  In the UI you do this by adding a Fix constraint.  In the API you can set the isFixed property of the SketchCircle object to True.  The only reason to add dimension constraints is if you want to edit the diameter or positions of the circles parametrically.  Changing them to be fixed will be easier and faster.
Brian Ekins
