How to determine "Hole Tap Type" from HoleFeature
kandennti
Mentor Mentor
kandennti
Hi there.
Does anyone know how to determine what the "Hole Tap Type" is set to from the HoleFeature in the timeline?
BrianEkins
I thought this was there but I don't see it either. I believe when support for holes was first implemented in the API, Fusion didn't support threaded holes and you had to create a hole and then add a thread feature to the resulting cylinder to get a thread. This should be added to the API.
Brian Ekins
kandennti
Thanks for the reply @BrianEkins .
I tried it and found that "Tapped" is in ThreadFeature.
I have created a script in response to an inquiry on the Japanese forum to "turn on/off the modeling of all screws".
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        threads: adsk.fusion.ThreadFeatures = root.features.threadFeatures
        # query
        msg = f'There is{threads.count} modelable screw. '
        msg += f'Do you want to model it all?\n'
        msg += f'Yes:Perform modeling\n'
        msg += f'No:Unmodel\n'
        msg += f'Cancel:Cancel'
        res = ui.messageBox(
            msg,
            'Modeling switch for all screws',
            adsk.core.MessageBoxButtonTypes.YesNoCancelButtonType,
            adsk.core.MessageBoxIconTypes.QuestionIconType
        # exec
        if res == adsk.core.DialogResults.DialogYes:
            execModeled(True)
        elif res == adsk.core.DialogResults.DialogNo:
            execModeled(False)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def execModeled(isModeled: bool):
    sels: adsk.core.Selections = ui.activeSelections
    tl: adsk.fusion.Timeline = des.timeline
    tlPos = tl.markerPosition
    thread: adsk.fusion.ThreadFeature
    for thread in threads:
        timeObj: adsk.fusion.TimelineObject = thread.timelineObject
        if thread.linkedFeatures.count < 1:
            # ThreadFeature
            timeObj.rollTo(True)
            if thread.isModeled != isModeled:
                thread.isModeled = isModeled
        else:
            # HoleFeature
            hole =  adsk.fusion.HoleFeature.cast(thread.linkedFeatures[0])
            if not hole:
                continue
            timeObj.rollTo(False)
            isModeledNumber = 1 if isModeled else 0
            sels.clear()
            sels.add(hole)
            app.executeTextCommand(u'Commands.Start FusionDcHoleEditCommand')
            dialogInfo = app.executeTextCommand(u'Toolkit.cmdDialog')
            if 'infoModeled' in dialogInfo:
                app.executeTextCommand(u'Commands.SetBool infoModeled {}'.format(isModeledNumber))
                app.executeTextCommand(u'NuCommands.CommitCmd')
    tl.markerPosition = tlPos
    sels.clear()
It does not work perfectly, but it works to some extent.
