- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there.
Does anyone know how to determine what the "Hole Tap Type" is set to from the HoleFeature in the timeline?
Hi there.
I thought this was there but I don't see it either. I believe when support for holes was first implemented in the API, Fusion didn't support threaded holes and you had to create a hole and then add a thread feature to the resulting cylinder to get a thread. This should be added to the API.
Thanks for the reply @BrianEkins .
I tried it and found that "Tapped" is in ThreadFeature.
I have created a script in response to an inquiry on the Japanese forum to "turn on/off the modeling of all screws".
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
ui: adsk.core.UserInterface = None
try:
app: adsk.core.Application = adsk.core.Application.get()
ui = app.userInterface
des: adsk.fusion.Design = app.activeProduct
root: adsk.fusion.Component = des.rootComponent
threads: adsk.fusion.ThreadFeatures = root.features.threadFeatures
# query
msg = f'There is{threads.count} modelable screw. '
msg += f'Do you want to model it all?\n'
msg += f'Yes:Perform modeling\n'
msg += f'No:Unmodel\n'
msg += f'Cancel:Cancel'
res = ui.messageBox(
msg,
'Modeling switch for all screws',
adsk.core.MessageBoxButtonTypes.YesNoCancelButtonType,
adsk.core.MessageBoxIconTypes.QuestionIconType
# exec
if res == adsk.core.DialogResults.DialogYes:
execModeled(True)
elif res == adsk.core.DialogResults.DialogNo:
execModeled(False)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def execModeled(isModeled: bool):
sels: adsk.core.Selections = ui.activeSelections
tl: adsk.fusion.Timeline = des.timeline
tlPos = tl.markerPosition
thread: adsk.fusion.ThreadFeature
for thread in threads:
timeObj: adsk.fusion.TimelineObject = thread.timelineObject
if thread.linkedFeatures.count < 1:
# ThreadFeature
timeObj.rollTo(True)
if thread.isModeled != isModeled:
thread.isModeled = isModeled
else:
# HoleFeature
hole = adsk.fusion.HoleFeature.cast(thread.linkedFeatures[0])
if not hole:
continue
timeObj.rollTo(False)
isModeledNumber = 1 if isModeled else 0
sels.clear()
sels.add(hole)
app.executeTextCommand(u'Commands.Start FusionDcHoleEditCommand')
dialogInfo = app.executeTextCommand(u'Toolkit.cmdDialog')
if 'infoModeled' in dialogInfo:
app.executeTextCommand(u'Commands.SetBool infoModeled {}'.format(isModeledNumber))
app.executeTextCommand(u'NuCommands.CommitCmd')
tl.markerPosition = tlPos
sels.clear()
It does not work perfectly, but it works to some extent.
