How to create one NC with the same name
nubrandao
nubrandao
Hi, for example, in the company my collegs use a lot probing, mostly fusion for probing,
they create one toolpath (probing), rename
the create one NC program, inside input toolpath manually
then post, and rename the NC again , so, they are renaming a lot of times.
is possible to select one toolpath and create one NC and rename automaticly?
i will create a video of what i want.
(view in My Videos)
to me i have to be honest , is not very important because i dont probe a lot.
basically they want rename once (toolpath) then with shift+s run script to the selected toolpath, create a nc program with same name on title and inside
Jorge_Jaramillo
In this topic:
https://forums.autodesk.com/t5/fusion-api-and-scripts/compare-and-edit-after-running-script/td-p/129...
you can an example of how to generate NC program por setup, assign it a name, and even assign a specific post-processor.
I hope it can help you.
Jorge Jaramillo
kandennti
Hi @nubrandao -San.
I made a sample.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        # Select Count check
        sels: core.Selections = ui.activeSelections
        if not sels.count == 1: return
        # Select Operation
        ope: cam.Operation = sels.item(0).entity
        # Create NcProgram Input
        camObj: cam.CAM = app.activeProduct
        ncProgs: cam.NCPrograms = camObj.ncPrograms
        ncInput: cam.NCProgramInput = ncProgs.createInput()
        # Set Name
        ncInput.displayName = ope.name
        # Set Nc Program Name
        ncInput.parameters.itemByName("nc_program_name").value.value = ope.name
        # Set Operation
        ncInput.operations = [ope]
        # Create NcProgram
        ncProgs.add(ncInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
nubrandao
hi, that is perfect, could be possible to do the same thing but with multiple selections?
kandennti
@nubrandao -San.
What you are doing here on this topic is what you hope to do.
https://forums.autodesk.com/t5/fusion-api-and-scripts/api-create-one-nc-for-each-toolpath/td-p/12994...
Slight modification.
import traceback
def run(context):
    try:
        if sels.count < 1: return
        # Select Operation
        opeLst: list[cam.Operation] = [sel.entity for sel in sels]
        for ope in opeLst:
            # Set Name
            # Set Operation
            # Create NcProgram
    except:
        if ui:
nubrandao
You are the best, that's a life saver in company. Thanks a lot
