How to create an operation from a sketch?
janHUUUQ
janHUUUQ
Is it possible to create an operation using a sketch for geometry selection?
I tried to adapt Manufacturing Workflow API Sample more specifically I took this piece from the linked code:
# limitEdge.classType() == 'adsk::fusion::BRepEdge'
cadcontours2dParam: adsk.cam.CadContours2dParameterValue = input.parameters.itemByName('machiningBoundarySel').value
chains = cadcontours2dParam.getCurveSelections()
chain = chains.createNewChainSelection()
chain.inputGeometry = [limitEdge]
cadcontours2dParam.applyCurveSelections(chains)
And tried to replace the line that sets the geometry with something like:
# sketch_lines.classType() == 'adsk::fusion::SketchLineList'
chain.inputGeometry = sketch_lines
Which gave me:
TypeError: in method 'CurveSelection__set_inputGeometry', argument 2 of type 'std::vector< adsk::core::Ptr< adsk::core::Base >,std::allocator< adsk::core::Ptr< adsk::core::Base > > > const &'
I also tried to pass a list `[sketch_lines]` instead, which gave a similar error.
* Is it possible to select an operation geometry based on a sketch?
* What types can inputGeometry handle? The only hint in the docs I found was, which is too broad to help me:
This is a read/write property whose value is an array of type Base.
kandennti
Hi @janHUUUQ -San.
I set the inputGeometry property as a list and the error no longer occurs.
Please modify some of the linked samples and run them.
        if limitEdge:
            # apply the limits edge to the operation
            # chain.inputGeometry = [limitEdge]
            # cadcontours2dParam.applyCurveSelections(chains)
            circle: adsk.fusion.SketchCircle = create_circle(cam)
            chain.inputGeometry = [circle]
def create_circle(cam: adsk.cam.CAM) -> adsk.fusion.SketchCircle:
    rootOcc: adsk.fusion.Occurrence = cam.designRootOccurrence
    root: adsk.fusion.Component = rootOcc.component
    skt: adsk.fusion.Sketch = root.sketches.add(
        root.xYConstructionPlane
    sktCircles: adsk.fusion.SketchCircles = skt.sketchCurves.sketchCircles
    return sktCircles.addByCenterRadius(
        adsk.core.Point3D.create(0,0,0),
        1,
janHUUUQ
Thanks a lot! Your snippet works for me, I did pass wrong types. Here are some types I tried and what worked for me:
  • FAIL: adsk.Fusion.SketchLineList
  • FAIL: list[adsk.Fusion.SketchLineList]
  • FAIL: adsk.fusion.Sketch
  • SUCCESS: list[adsk.fusion.Sketch]
  • FAIL: adsk.fusion.SketchCircle
  • SUCCESS: list[adsk.fusion.SketchCircle]
janHUUUQ
I still have issues.I adapted your function as follows:
def create_rect(cam: adsk.cam.CAM) -> adsk.fusion.Sketch:
    lines = skt.sketchCurves.sketchLines
    rect_lines = lines.addTwoPointRectangle(
        adsk.core.Point3D.create(-1, -1, 5),
        adsk.core.Point3D.create(1, 1, 5),
    return skt
While I can pass my rectangle as a `list[adsk.fusion.Sketch]` without getting an exception, I somehow get a toolpath that does not seem to care about my rectangle:
If I manually reselect the sketch boundary in the gui the restriction works as expected:
This is what the API call gave me:
And this is what works:
kandennti
@janHUUUQ -San.
The return value of the function was changed to "rect_lines" instead of the sketch itself.
The type of "rect_lines" was "adsk::fusion::SketchLineList", but it was necessary to convert it to a list.
        if limitEdge:
            # chain.inputGeometry = [limitEdge]*************
            rectLines = create_rect(cam)
            print(rectLines.objectType) # -> adsk::fusion::SketchLineList - NG
            chain.inputGeometry = list(rectLines)
    # return skt
    return rect_lines
janHUUUQ
Awesome this works!
