How to create a square pipe using PipeFeatures?
ph0en1x01
ph0en1x01
I want to create a square pipe using PipeFeatures. But I am unable to find an example related to it.
kandennti
Hi @ph0en1x01 .
The API does not provide a way to create pipe features.
I believe it is possible to create the same shape using sweeps.
If you really want to create a pipe feature, the only way is to use the text command.
By slightly modifying the initPipe function in the sample here, it is possible to create a square pipe.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/use-textcommands/m-p/9645688
def initPipe(path):
    sels :adsk.core.Selections = _ui.activeSelections
    sels.clear()
    sels.add(path)
    txtCmds = [
        u'Commands.Start PrimitivePipe',
        u'Commands.SetDouble SWEEP_POP_ALONG 1.0',
        u'Commands.SetString infoSectionType infoRectangular',
        u'Commands.SetDouble SectionRadius 0.5',
        u'Commands.SetBool PIPE_HOLLOW_OPTION 1',
        u'Commands.SetDouble SectionThickness 0.1',
        u'NuCommands.CommitCmd'
    for cmd in txtCmds:
        _app.executeTextCommand(cmd)
    sels.clear()
However, we recommend using sweeps.
