how to create a nurbs2d curve into sketch?
2022282210229
2022282210229
There is a nurbscurve2d.createrational method,but no funtion to add it into sketch,does anybody know how to
achieve it,thank you very much!!!
kandennti
Hi @2022282210229 .
All elements in the sketch must be 3D.
If they are NurbsCurve3D, they can be included in the sketch using the SketchFixedSplines.addByNurbsCurve method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-EA5FBD51-ED6F-4D04-83B2-D72A384BC6DA
thanks for your reply,i see that 3d nurbs curve is unable to be modified in fusion 360,do you have solotion to solve it?thank you very much!
BrianEkins
What is it that you're trying to do? After creating a SketchFixedSpline you can use the replaceGeometry method to update it with a new NURBS definition.
Brian Ekins
i want to create a editable nurbs curve through code,now i have realized it!  thanks  for your reply!!
