How to change angle manipulator's origin in preview
hajime2MRG3
hajime2MRG3
I cannot find the way to change angle manipulator's origin in preview. I can set the origin in CreatedEventHandler.notify(), but not in PreviewHandler.notify(). Is it impossible?
The code below should move the origin when SelectionCommandInput worked first time, but it doesn't happen.
import sys
import traceback
import adsk.core as ac
import adsk.fusion as af
import adsk
HANDLERS = []
BUTTON_ID = "test_angle_manipulator_button"
SELECT_OCC_ID = 'select_occ'
INP_ANGLE_ID = 'input_angle'
def notify_catcher(func):
    def f(*args, **kwargs):
        try:
            func(*args, **kwargs)
        except Exception:
            print(traceback.format_exc(), file=sys.stderr)
    return f
class MyExecutePreviewHandler(ac.CommandEventHandler):
    def __init__(self):
        super().__init__()
    @Anonymous_catcher
    def notify(self, args):
        cmd_args = ac.CommandEventArgs.cast(args)
        cmd_inputs = cmd_args.command.commandInputs
        angle_input = ac.AngleValueCommandInput.cast(cmd_inputs.itemById(INP_ANGLE_ID))
        angle_input.manipulatorOrigin.set(-1, 2, 0)
class MyExecuteHandler(ac.CommandEventHandler):
    def __init__(self):
        super().__init__()
    @Anonymous_catcher
        pass
class MyCommandCreatedHandler(ac.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    @Anonymous_catcher
        # Code to react to the event.
        command = ac.Command.cast(args.command)
        cmd_inputs = command.commandInputs
        sel_input = cmd_inputs.addSelectionInput(SELECT_OCC_ID, 'Selection', 'Select an occurrence')
        sel_input.addSelectionFilter('Occurrences')
        sel_input.setSelectionLimits(1, 1)
        angle_input = cmd_inputs.addAngleValueCommandInput(INP_ANGLE_ID, 'Angle', ac.ValueInput.createByString('0 degree'))
        origin = ac.Point3D.create(1, 2, 0)
        vx = ac.Vector3D.create(1, 0, 0)
        vy = ac.Vector3D.create(0, 1, 0)
        angle_input.setManipulator(origin, vx, vy)
        angle_input.isEnabled = True
        angle_input.hasMinimumValue = False
        angle_input.hasMaximumValue = False
        # Connect to the execute preview and execute events.
        on_exec_preview = MyExecutePreviewHandler()
        command.executePreview.add(on_exec_preview)
        HANDLERS.append(on_exec_preview)
        on_exec = MyExecuteHandler()
        command.execute.add(on_exec)
        HANDLERS.append(on_exec)
@notify_catcher
def run(context):
    app = ac.Application.get()
    ui = app.userInterface
    # create the button definition and add a control to the INSPECT panel.
    button_def = ui.commandDefinitions.itemById(BUTTON_ID)
    if button_def:
        button_def.deleteMe()
    button_def = ui.commandDefinitions.addButtonDefinition(BUTTON_ID, 'Angle Manipulator Test', 'Angle Manipulator Test.', 'Resources/Geometry')
    on_cmd_created = MyCommandCreatedHandler()
    button_def.commandCreated.add(on_cmd_created)
    HANDLERS.append(on_cmd_created)
    inspect_panel = ui.allToolbarPanels.itemById('InspectPanel')
    ctrl = inspect_panel.controls.itemById(BUTTON_ID)
    if ctrl:
        ctrl.deleteMe()
    inspect_panel.controls.addCommand(button_def)
@notify_catcher
def stop(context):
    if button_def:
    if ctrl:
        ctrl.deleteMe()
hajime2MRG3
I've found the way.
# Author-
# Description-
import sys
import traceback
import adsk
HANDLERS = []
        try:
        except Exception:
    return f
class MyInputChangedHandler(adsk.core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    @Anonymous_catcher
        ic_args = ac.InputChangedEventArgs.cast(args)
        changed_input = ic_args.input
        if changed_input.id == INP_ANGLE_ID:
            return
        cmd_inputs: ac.CommandInputs = ic_args.firingEvent.sender.commandInputs
        origin = ac.Point3D.create(-1, 2, 0)
    def __init__(self):
        super().__init__()
    @Anonymous_catcher
        pass
    def __init__(self):
        super().__init__()
    @Anonymous_catcher
        pass
    def __init__(self):
        super().__init__()
    @Anonymous_catcher
        on_input_changed = MyInputChangedHandler()
        command.inputChanged.add(on_input_changed)
        HANDLERS.append(on_input_changed)
@notify_catcher
def run(context):
    if button_def:
    if ctrl:
        ctrl.deleteMe()
@notify_catcher
def stop(context):
    if button_def:
    if ctrl:
        ctrl.deleteMe()
