How to add a constraint so a spline handle?
a.g.ashwood
a.g.ashwood
Hi All,
I am still learning the API so please be kind 🙂
I am trying to write a script which generates pathing information and I have come across a problem joining two lines in a consistent way. If we take two lines and put a spline between them then I get something like this:
Now, in the GUI I would grab the handles of these two points and make them colinear with the incoming and outgoing lines like this:
Which results in a lovely curving path:
However, when I try and do this via the API using this code:
def makeSpline(sketch : adsk.fusion.Sketch,startPoint : adsk.fusion.SketchPoint, endPoint : adsk.fusion.SketchPoint, startLine : adsk.fusion.SketchLine, endLine : adsk.fusion.SketchLine) :
    points = adsk.core.ObjectCollection.create()
    points.add(startPoint)
    points.add(endPoint)
    splines = sketch.sketchCurves.sketchFittedSplines
    spline = splines.add(points)
    handle = spline.activateCurvatureHandle(startPoint)
    sketch.geometricConstraints.addCollinear(startLine, handle)
    handle = spline.activateCurvatureHandle(endPoint)
    sketch.geometricConstraints.addCollinear(endLine, handle)
    return spline
I get an error:
What am I doing wrong here?
TIA
Andy
kandennti
Hi @a.g.ashwood -San.
I had never tried it before, so I gave it a shot.
I have rewritten the makeSpline function significantly, but this does not cause any errors.
Is this the desired result?
# Fusion360API Python script
import traceback
import adsk.core
import adsk.fusion
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        skt: adsk.fusion.Sketch = root.sketches.add(
            root.xYConstructionPlane
        startLine: adsk.fusion.SketchLine = create_sketch_line(
            skt,
            [0,1,0],
            [1,1,0],
        endLine: adsk.fusion.SketchLine = create_sketch_line(
            skt,
            [3,3,0],
            [4,3,0],
        makeSpline(
            skt,
            startLine.endSketchPoint,
            endLine.startSketchPoint,
            startLine,
            endLine,
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_sketch_line(
    skt: adsk.fusion.Sketch,
    sPos: list[float],
    ePos: list[float],
) -> adsk.fusion.SketchLine:
    line: adsk.fusion.SketchLine = skt.sketchCurves.sketchLines.addByTwoPoints(
        adsk.core.Point3D.create(sPos[0], sPos[1], sPos[2],),
        adsk.core.Point3D.create(ePos[0], ePos[1], ePos[2],),
    line.isFixed = True
    return line
def makeSpline(
    sketch: adsk.fusion.Sketch,
    startPoint: adsk.fusion.SketchPoint,
    endPoint: adsk.fusion.SketchPoint,
    startLine: adsk.fusion.SketchLine,
) -> adsk.fusion.SketchFittedSpline:
    points: adsk.core.ObjectCollection = adsk.core.ObjectCollection.createWithArray(
        [startPoint, endPoint]
    # create spline
    splines: adsk.fusion.SketchFittedSplines = sketch.sketchCurves.sketchFittedSplines
    spline: adsk.fusion.SketchFittedSpline = splines.add(points)
    fitPoints = list(spline.fitPoints)
    # create Collinear startline - spline start handle
    sFitPoint: adsk.fusion.SketchPoint = fitPoints[0]
    spline.activateCurvatureHandle(sFitPoint)
    curvatureHandle: adsk.fusion.SketchArc = spline.getCurvatureHandle(sFitPoint)
    curvatureHandle.deleteMe()
    tangentHandle: adsk.fusion.SketchLine = spline.getTangentHandle(sFitPoint)
    sketch.geometricConstraints.addCollinear(tangentHandle, startLine)
    # create Collinear endline - spline end handle
    eFitPoint: adsk.fusion.SketchPoint = fitPoints[-1]
    spline.activateCurvatureHandle(eFitPoint)
    curvatureHandle: adsk.fusion.SketchArc = spline.getCurvatureHandle(eFitPoint)
    tangentHandle: adsk.fusion.SketchLine = spline.getTangentHandle(eFitPoint)
    sketch.geometricConstraints.addCollinear(tangentHandle, endLine)
    return spline
a.g.ashwood
That's exactly what I was after!
Thanks a lot.
