- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've recently purchased a CNC mill and want to use the UGS_Fusion add-in.
I am using the Fusion Grbl post process. The way I like to set up the machine is to position the spindle at a point, zero XY, and Probe Z. This means I want to use the Safe Retracts = Clearance Height option in post process.
When I generate the NC file with Actions > Post Process all is good. The G28 lines are removed from the nc code.
The problem is when I use the UGS_Fusion plugin. The add-in doesn't recognize the Safe Retracts option and exports the nc code with the G28 line included.
Can anyone guide me on how to get the Safe Retracts recognized in the python code?
