How is the image2surface addin installed on fusion 360 usinG a mac?
wn002
wn002
Would like to use but can't seem to install
hanskellner
I'm assuming you are asking about my add-in that's found here:
hanskellner/Fusion360Image2Surface: Image2Surface Add-In for Autodesk Fusion 360 (github.com)
The README provides a link to install instructions as well as additional notes on installation.  The install help link is duplicated here:
How to install an add-in or script in Fusion 360 (autodesk.com)
Look for the section on manual installs.
One other option, others have suggested, is to use this for installing from Github (where the add-in is hosted):
Install scripts or addins from GitHub | Fusion 360 | Autodesk App Store
Hans Kellner
Senior Manager, Principal Engineer
wn002
Thank you, installed and tested, I will try working with the artwork soon
Wade
