How is best to create a plane on a spline path?
MichaelAubry
Alumni Alumni
MichaelAubry
Hi!  I'm continuing to build out my fibonacci script. It takes input values now!  I'm trying to make the program create a loft along a centerline but I'm getting stuck at creating the planes along the path I'll need to make loft profiles.  Can you take a look at my code?
Here's what I'm working towards:
Thank you!
Mike
import adsk.core, adsk.fusion
app= adsk.core.Application.get()
design = app.activeProduct
ui = app.userInterface
#**Default User Inputs**
steps = "5 cm" #How many steps of Fibonacci would you like to plot?
#(Note, while the steps variable should be unitless, right now our API can't handle unitless number.
#cm are the absolute units we use on the API side.)
length = "3 cm" #How long is the first segment? (cm)
input = steps
createInput = ui.inputBox('Enter Steps', 'Steps', input)
if createInput[0]:
(input, isCancelled) = createInput
unitsMgr = design.unitsManager
realSteps = unitsMgr.evaluateExpression(input, unitsMgr.defaultLengthUnits)
input = length
createInput = ui.inputBox('Enter Length', 'Length', input)
if createInput[0]:
realLength = unitsMgr.evaluateExpression(input, unitsMgr.defaultLengthUnits)
#Get root component
rootComp = design.rootComponent
#Create a new sketch on XY plane
sketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
# Create an object collection for the points.
points = adsk.core.ObjectCollection.create()
# R = total steps to be run thru the For loop
R = int(realSteps - 2)
#starting x and y coordiantes
x = 0
y = 0
#Create 1st coordinate
points.add(adsk.core.Point3D.create(x,y,0))
#starting values for sequence
fib = 1
fib1 = 1
#Create 2nd coordinate
x = 1 * realLength
ui.messageBox('x: ' + str(x))
#bins for shifting x and y coordinates
Bin1 = range(0,R,4)
Bin2 = range(1,R,4)
Bin3 = range(2,R,4)
Bin4 = range(3,R,4)
for i in range(R):
fib2 = fib + fib1
fib = fib1
fib1 = fib2
fibLength = fib*realLength #adds the scalar component to coordinates
ui.messageBox('fiblength: ' + str(fibLength))
if i in Bin1:
x = x
y = y + fibLength
if i in Bin2:
x = x - fibLength
y = y
if i in Bin3:
x = x
y = y - fibLength
if i in Bin4:
x = x + fibLength
y = y
# Create the spline.
sketch.sketchCurves.sketchFittedSplines.add(points)
# Create the Planes for the loft
spline1 = sketch.sketchCurves.sketchFittedSplines.item(0)
plane1 = rootComp.ConstructionPlaneInput.setByDistanceOnPath.add(spline1,0)
Michael Aubry
Autodesk Fusion 360 Evangelist
xiaohui.wang
Hi Michael,
Please have a try to replace 'plane1 = rootComp.ConstructionPlaneInput.setByDistanceOnPath.add(spline1,0)' with the following code .
    planeInput = rootComp.constructionPlanes.createInput() # you could also specify the occurrence in the parameter list
    planeInput.setByDistanceOnPath(spline1, adsk.core.ValueInput.createByReal(0))
    plane1 = rootComp.constructionPlanes.add(planeInput)
Besides, loft feature hasn't been included in the API yet. Sorry for the inconvenience.
Xiaohui
Xiaohui Wang
SW Engineer
MichaelAubry
Success!  Thanks so much. Your soluiton worked like a charm.
Thanks for the warning that we don't have loft from the API yet.  Thats's okay. I'll just set the script up to get to that point.
Thank you!
Mike
Michael Aubry
MichaelAubry
For those following the thread, here's what the final solution ended up as.
Gallery Post: https://fusion360.autodesk.com/projects/horn-of-fibonacci
Code: https://github.com/MichaelAubry/Fusion360.git
Video:
Big thanks to Brian, Xiaohui, and Casey for helping with this!
Best,
Mike
Michael Aubry
