how I can import an exist file and modify it ?
mohammadkhader698
mohammadkhader698
I try to make a script to import an exist file I export it on my pc to modify it ?
which command I need to use ?
kandennti
Hi @mohammadkhader698 .
If the document is in the data panel, there is no need to export it.
The documents "A" and "B" are in the same folder, and the following script is executed with "A" open.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        # Search Ducument(DataFile)
        targetDocumentName = 'B'
        df: adsk.core.DataFile = getDataFileByName(targetDocumentName)
        if not df:
            return
        # Insert DataFile
        # https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-D2921ADB-3556-4B9E-98ED-2598EDDB852A
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        root.occurrences.addByInsert(
            df,
            adsk.core.Matrix3D.create(),
            False
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def getDataFileByName(
    name: str) -> adsk.core.DataFile:
    dataFolder: adsk.core.DataFolder = app.activeDocument.dataFile.parentFolder
    for df in dataFolder.dataFiles.asArray():
        if df.name == name:
            return df
    return None
After execution, "B" will end up being inserted.
