How do I get the item ID from a selected entity in a sketch?
m.s.peglar
m.s.peglar
Hi everyone,
I'm trying to get the coords of the start point of a user selected line inside a sketch. I have managed to get the entity and test that it is a line, but how do I then get the line ID of the entity so i can get the coords?
I *think* it might be something to do with cast but I really can't work it out!
thanks in advance!
Ptr<Selection> selection1 = ui->activeSelections()->item(0);
Ptr<Base> selectedEnt1 = selection1->entity();
if (selectedEnt1->objectType() != LINE_TYPE) {
  ui->messageBox("Selected entities are not sketch lines.");
  return false;
int ID = *HOW DO I GET THIS?*
Ptr <Point3D> p0 = lines->item(ID)->startSketchPoint()->worldGeometry();
double x = p0->x();
double y = p0->y();
double z = p0->z();
nnikbin
Hi @m.s.peglar
You are right, one solution is casting. You can use the automatic casting performed by the Ptr template and you do not need any ID.
Ptr<SketchLine> sketchLine = Ptr<SketchLine>(selectedEnt1);
Ptr<Point3D> p0 = sketchLine->worldGeometry()->startPoint();
Here in Object Types and Casting section you can find useful relevant information.
m.s.peglar
You couldn't have answered better! Thanks for your help again Navid! It's really very appreciated 🙂
