How do I control command dialogBox buttons.
obatake5TC3R
obatake5TC3R
I would like to control a command dialogbox button.
For example OK button is disable or enable.  And to focus input object item.
If you have any sample programs(cpp) tell me.
marshaltu
You can probably use validateInputs event in the command to enable/disable "OK" button in command dialog. Please refer to the following help. Unfortunately I didn't find the way to let you change focus of command input.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-48f1c5e6-9c63-4da4-b0eb-6701e8569013
Marshal
Marshal Tu
Fusion Developer
erik
I also found, that there is no way to change the focus of command inputs and have therefore created a request on the Idea Station for this suggestion.
Link: https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/auto-selection-of-command-input/idi-...
- Erik
