How do I add a graphic to my new toolbar item?
OceanHydroAU
OceanHydroAU
I'm struggling with the ToolbarPanels.add Method ( https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-165e8619-babe-4448-a79b-ff7d5dfac8aa )
My icon for my button is not showing up:-
I've got a ./resources folder with 32x32.png and 64x64.png etc in it, but I can't work out how I tell the ".add" method to *use* them - here's my code.  I did manage to figure it out for the commands, but that's becuase those methods let you tell it where the resource folder is - how do I tell ToolbarPanels.add this?
import adsk.core, adsk.fusion, adsk.cam, traceback
tbPanel = None
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        workSpace = ui.workspaces.itemById('FusionSolidEnvironment')
        tbPanels = workSpace.toolbarPanels
        global tbPanel
        tbPanel = tbPanels.itemById('NewPanel')
        if tbPanel:
            tbPanel.deleteMe()
        tbPanel = tbPanels.add('NewPanel', 'AirFoil Tools', 'SelectPanel', False)  # This fails to put any button onto my new panel item.
        # Empty panel can't be displayed. Add a command to the panel
        cmdDef = ui.commandDefinitions.itemById('NewCommand')
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = ui.commandDefinitions.addButtonDefinition('NewCommand', 'Import DAT', 'Load and optimise a dat to a spline', './resources') # This works, with its own tiny button.
        tbPanel.controls.addCommand(cmdDef)
        ui.messageBox('Hello addin')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def stop(context):
    ui = None
    try:
        if tbPanel:
            tbPanel.deleteMe()
        ui.messageBox('Stop addin')
    except:
        if ui:
kandennti
Hi @OceanHydroAU .
Use the isPromotedByDefault property of the CommandControl object.
        if cmdDef:
            cmdDef.deleteMe()
        # tbPanel.controls.addCommand(cmdDef)
        cmdControl :adsk.core.CommandControl = tbPanel.controls.addCommand(cmdDef) # here
        cmdControl.isPromotedByDefault = True # here
