how can show a help picture when mouse on a textbox.
ho-kou
ho-kou
hi, everyone
I want to show a help picture when mouse on  a textbox like the picture.
eg. when mouse move on Tool Orientation, the help picture will be showed.
Thank your for your help.
kandennti
Hi @ho-kou -San.
For TextBoxCommandInput, it seems that HTML formatting tags can be used in the tooltipDescription property.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-fd65f2ef-ad50-4888-900c-3daa169133a8
I made a sample here.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
    'id': 'kantoku_test',
    'name': 'test',
    'tooltip': 'test'
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        core.Application.get().log(args.firingEvent.name)
        try:
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            cmd.isOKButtonVisible = False
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            inputs: core.CommandInputs = cmd.commandInputs
            txtIpt: core.TextBoxCommandInput = inputs.addTextBoxCommandInput(
                'txtIpt',
                'test',
                1,
                False,
            txtIpt.tooltip = "tooltip"
            txtIpt.tooltipDescription = "<h1>tooltipDescription</h1>"
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        adsk.terminate()
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO['id']
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO['id'],
                CMD_INFO['name'],
                CMD_INFO['tooltip']
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
The execution result is here. When the mouse cursor is hovered over TextBoxCommandInput for a certain period of time, tooltipDescription is displayed.
ho-kou
hi @kandennti
Thank you verymuch for your code.
ho-kou
Succeeded to use toolClipFilename to show picture.
