How can I delete a parameter?
marcosscriven
marcosscriven
I can add a parameter via the design.userParameters list - even though it claims to be read-only.
However, the deleteByItem method results in a read-only error, and I see no way to get a mutable one.
It seems the API is setup for adding and deleting user parameters, but deleting them doesn’t work as there’s no access to a mutable user parameter list.
You have to call the parameter's deleteMe() function.
UserParameter::deleteMe
marcosscriven
Thanks so much - that worked.
davidpbest
OK, what is the phone number for the parameter's deleteMe() function..  Seriously, I have no idea what you're talking about.  Please elaborate on how to accomplish the "call parameter's deleteMe() function" operation.
kandennti
Hi @davidpbest -San.
User parameters can be obtained from the UserParameters property of the Design object.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-ba26f8cd-6136-44a8-81fe-b133198cfa2d
We did a little testing.
I created two user parameters and used one in the extrusion.
Then we run this script.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        for name in ["length1", "length2"]:
            param = des.userParameters.itemByName(name)
            res = param.deleteMe()
            print(f"Were you able to delete '{name}'? : {res}")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Were you able to delete 'length1'? : True
Were you able to delete 'length2'? : False
The used user parameter could not be deleted by executing the deleteMe method.
davidpbest
I have no interest in using some API or writing code/scripts.  But thanks for your suggestion
