how can get face' raduis?
ho-kou
ho-kou
Hi everyone,
I want to get(measure) face' radius .
who know how can do it.
Thankyou for your help.
kandennti
Hi @ho-kou -San.
A script was created to select a cylindrical surface and display its radius.
The radius is obtained within the get_radius function.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        msg: str = "Select"
        selFilter: str = "CylindricalFaces"
        sel: core.Selection = select_ent(msg, selFilter)
        if not sel:
            return
        radius = get_radius(sel.entity)
        if not radius: return
        unitsMgr: core.UnitsManager = des.unitsManager
        ui.messageBox(
            f"{unitsMgr.formatInternalValue(radius)}",
            "Radius",
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def get_radius(
    face: fusion.BRepFace,
) -> float:
    geo = face.geometry
    if geo.classType() != core.Cylinder.classType(): return None
    cylinder: core.Cylinder = geo
    return cylinder.radius
def select_ent(
    msg: str,
    filterStr: str
) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
ho-kou
hi @kandennti
Thank you very much for your code.
But i want to measure the brepface which type is "adsk.core.NurbsSurface".
Do you give me other idea.
Thank you for your help.
kandennti
@ho-kou -San.
The following sample displays the radius at the clicked position of a face.
The curvature is the reciprocal of the radius.
import traceback
def run(context):
    try:
        # select face
        msg: str = 'Select Face'
        selFilter: str = 'Faces'
        if not sel: return
        # get curvature
        curvature = get_curvature(
            sel.entity,
            sel.point,
        # get raduis
        if curvature == 0:
            raduis = "-"
        else:
            raduis = unitsMgr.formatInternalValue(
                abs(1 / curvature)
        ui.messageBox(raduis, "Raduis")
    except:
        if ui:
def get_curvature(
    point: core.Point3D,
) -> float:
    # https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-31dad9b2-ee1d-4216-8100-09ea44f9967a
    eva: core.SurfaceEvaluator = face.evaluator
    _, prm = eva.getParameterAtPoint(point)
    _, _, curvature, _ = eva.getCurvature(prm)
    return curvature
def select_ent(
    msg: str,
    filterStr: str
    try:
        return sel
    except:
        return None
All add-ins here are in Japanese, but the same process is used to display the radius of the mouse cursor position in real time.
https://github.com/kantoku-code/Fusion360_OnTheFly/tree/master
