Hide bodies from the user interface
victoriaN4VP7
victoriaN4VP7
Is there a function to hide bodies from the user interface? I am trying to hide all bodies from view with the exception of 'Body 6' remaining visible using python script rather than clicking in the design tree to hide each body.
Jorge_Jaramillo
The shortcut "V" hides the selected bodies.
What you want could be developed with an add-in that hides all bodies other that the selected ones.
Jorge Jaramillo
victoriaN4VP7
Hi Jorge,
I am looking for a python code or function that I can insert into an existing script that would hide all visible bodies in the design with exception of one body.
Thanks!
Jorge_Jaramillo
Hi Victoria,
The following recursive script will hide all bodies except the name supplied as second argument:
def hide_all_bodies_except_one(comp: adsk.fusion.Component, body_name: str):
    for body in comp.bRepBodies:
        if body.name != body_name:
            body.isLightBulbOn = False
    for occ in comp.occurrences:
        if occ.component:
            hide_all_bodies_except_one(occ.component, body_name)
You can call it like:
hide_all_bodies_except_one(root, "Body6")
In this case it will hide all bodies except the ones with name "Body6".
It wont check if the body is visible or not, which could also be added.  As a reminder a body is visible if itself has bulb on and also all its parent component are also visible.
Does this met your needs?
I hope this could help you.
Jorge Jaramillo
kandennti
Hi @Jorge_Jaramillo -San.
By using the Component.findBRepUsingPoint method and setting proximityTolerance to a large value, you can efficiently obtain only the displayed BreoBody.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-98FA52AD-C930-42D5-B67B-41ACB1691DBB
def hide_all_bodies_except_one(body_name: str):
    app: adsk.core.Application = core.Application.get()
    des: adsk.fusion.Design = app.activeProduct
    root: fusion.Component = des.rootComponent
    import sys
    showBodies = root.findBRepUsingPoint(
        adsk.core.Point3D.create(0,0,0),
        adsk.fusion.BRepEntityTypes.BRepBodyEntityType,
        sys.float_info.max,
    body: adsk.fusion.BRepBody = None
    for body in showBodies:
        if body.name == body_name: continue
