Help writing script/add-in
Hi
I am new to Fusion 360 and was wondering if I could get some help on writing a script\add-in, or if someone could write it for me.  I am not sure which one I need - either script or add-in.  I am creating cookie cutters and would like to simplify the steps required for 3 offset settings, 3 extrusion settings and filet settings.  I am able to manually apply the settings I use but would like a one step process to save time.
Any assistance would be greatly appreciated as this is beyond my skill set!
Hi h_poffen,
I've only written a few python scripts for Fusion, and here's a link to a video that got me started:  https://www.youtube.com/watch?v=nUk_aHVeYaw.
Greg
Rushikesh.kadam
@Anonymous for resources to start with API, please refer the link http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A92A4B10-3781-4925-94C6-47DA85A4F65A .
The same link can be accessed from Fusion application through Help >> Learning and Documentation >> Fusion 360 API.
It contains loads of data to work on Fusion API's. It also has videos for easy understanding.
To understand the difference between scripts and add-in refer to the topic 'Scripts vs. Add-Ins' in the link http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-9701BBA7-EC0E-4016-A9C8-964AA4838954
Rushikesh Kadam.
If my reply was helpful, please give a "Like" or click the "Accept as Solution" button below (or both).
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
nnikbin
Hi @Anonymous
The idea of creating an add-in or a script to facilitate your workflow is greate, but as a basic solution before writing any code, you can save time by using parameters.
This video and this tutorial could be useful as a starting point if you are not familiar with using parameters in Fusion 360.
