- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have cobbled together the following script that takes a user selected curve, draws a rectangle at each end based on user parameters with the intention of then lofting the profiles along the original curve. I have had all the parts working at various points but as yet not all together. I struggled for a while to make the rectangles parametrically adjustable but now that I have managed to sort that I'm lost as to how I can get the profiles from them that I need in order to loft. The script as pasted below works perfectly up until
#Create Loft
because I am unable to define the profiles
I think that because the sketch is being defined in a separate function(?) that I can't call the profiles with
profile1 = sketch.profiles[0]
as I was before.
I assume (hope) there is a way to grab the profiles from the sketch but I cannot find any way to do it. Any help would be much appreciated.
Many thanks in advance
Pete
#Description-Select a path to create loft.
import adsk.core, adsk.fusion, traceback, math
def oAddRect(sketches, plane, center, length_params):
# Reference the width and height user parameters values
app = adsk.core.Application.get()
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
userParams = design.userParameters
width = userParams.itemByName('BSOx').value
height = userParams.itemByName('BSOy').value
# Create the rectangle
sketch = sketches.add(plane)
sketchlines = sketch.sketchCurves.sketchLines;
p1 = adsk.core.Point3D.create(-width / 2, -height / 2, 0)
p2 = adsk.core.Point3D.create(width / 2, height / 2, 0)
recLines = sketchlines.addTwoPointRectangle(p1, p2)
# Constrain the Rectangle to stay rectangular
constraints = sketch.geometricConstraints
constraints.addPerpendicular(recLines.item(0), recLines.item(1))
constraints.addHorizontal(recLines.item(0))
constraints.addParallel(recLines.item(0), recLines.item(2))
constraints.addParallel(recLines.item(1), recLines.item(3))
# Add construction lines to constrain the rectangle to the center point
diagonal1 = lines.addByTwoPoints(recLines.item(0).startSketchPoint, recLines.item(2).startSketchPoint)
diagonal1.isConstruction = True
#diagonal1.isVisible = False
diagonal2 = lines.addByTwoPoints(recLines.item(1).startSketchPoint, recLines.item(3).startSketchPoint)
diagonal2.isConstruction = True
#diagonal2.isVisible = False
# Constrain the rectangle to be centered on the center point
sketchpoints = sketch.sketchPoints;
sk_center = sketchpoints.add(center)
sk_center.isfixed = True
constraints.addCoincident(sk_center, diagonal1)
constraints.addCoincident(sk_center, diagonal2)
constraints.addCoincident(sk_center, sketch.originPoint)
# Dimension the rectangle with the user parameters
w = sketch.sketchDimensions.addDistanceDimension(recLines.item(0).startSketchPoint, recLines.item(0).endSketchPoint,
adsk.fusion.DimensionOrientations.HorizontalDimensionOrientation,
adsk.core.Point3D.create(0, height, 0));
w.parameter.expression = 'BSOx'
h = sketch.sketchDimensions.addDistanceDimension(recLines.item(1).startSketchPoint, recLines.item(1).endSketchPoint,
adsk.fusion.DimensionOrientations.VerticalDimensionOrientation,
adsk.core.Point3D.create(width, 0, 0));
h.parameter.expression = 'BSOy'
def tAddRect(sketches, plane, center, length_params):
width = userParams.itemByName('BSTx').value
height = userParams.itemByName('BSTy').value
w.parameter.expression = 'BSTx'
h.parameter.expression = 'BSTy'
def run(context):
ui = None
try:
ui = app.userInterface
if not design:
ui.messageBox('It is not supported in current workspace, please change to MODEL workspace and try again.')
return
sel = ui.selectEntity('Select a path to create loft', 'Edges,SketchCurves')
selObj = sel.entity
comp = design.rootComponent
# create path
feats = comp.features
chainedOption = adsk.fusion.ChainedCurveOptions.connectedChainedCurves
if adsk.fusion.BRepEdge.cast(selObj):
chainedOption = adsk.fusion.ChainedCurveOptions.tangentChainedCurves
path = adsk.fusion.Path.create(selObj, chainedOption)
path = feats.createPath(selObj)
# create planes at each end
planes = comp.constructionPlanes
planeInput = planes.createInput()
planeInput.setByDistanceOnPath(selObj, adsk.core.ValueInput.createByReal(0))
plane1 = planes.add(planeInput)
planeInput.setByDistanceOnPath(selObj, adsk.core.ValueInput.createByReal(1))
plane2 = planes.add(planeInput)
#create sketch for origin
sketches = comp.sketches;
center = adsk.core.Point3D.create(0, 0, 0)
oAddRect(sketches, plane1, center, ['BSOx', 'BSOy'])
#create sketch for termination
tAddRect(sketches, plane2, center, ['BSTx', 'BSTy'])
#Create Loft
loft1 = comp.features.loftFeatures
loftInput = loft1.createInput(adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
loftSectionsObj = loftInput.loftSections
loftSectionsObj.add(profile1)
loftSectionsObj.add(profile2)
loftPath = loftInput.centerLineOrRails
loftPath.addCenterLine(path)
loftInput.isSolid = True
# Create loft feature
loft1.add(loftInput)
app.activeViewport.refresh()
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
