Get the sketches that belong to a child occurrence
Joshua.mursic
Joshua.mursic
I am trying to access the sketches that are part of this child occurrence.
I was able to get the bRepBodies, but I do not see how to get access to the sketches. Is this possible?
kandennti
Hi @Joshua.mursic .
When the attached f3d file is activated and the following script is executed, the coordinate values of the origin of the red arrow sketch are displayed.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        targetOcc: fusion.Occurrence = root.allOccurrences.itemByName('level3:1')
        targetComp: fusion.Component = targetOcc.component
        nativeSketch: fusion.Sketch = targetComp.sketches[0]
        proxySketch: fusion.Sketch = nativeSketch.createForAssemblyContext(targetOcc)
        msgLst = [
            f'nativeSketch.originPoint:{nativeSketch.originPoint.worldGeometry.asArray()}',
            f'proxySketch.originPoint:{proxySketch.originPoint.worldGeometry.asArray()}',
            f'nativeSketch.sketchPoints[0]:{nativeSketch.sketchPoints[0].worldGeometry.asArray()}',
            f'proxySketch.sketchPoints[0]:{proxySketch.sketchPoints[0].worldGeometry.asArray()}',
        ui.messageBox('\n'.join(msgLst))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Joshua.mursic
Thank you very much @kandennti, that's exactly what I needed.
