Get Selected Feature Properties From a Thread Feature
mike
mike
I'm trying to write a script that will automatically generate a thread undercut for when machining a thread on a lathe.
Is it possible to retrieve the thread properties after the thread feature has been selected in the command window. Such as;
selectionInput = inputs.addSelectionInput(commandId + '_selection', 'Select', 'Select bodies or occurrences')
selectionInput.setSelectionLimits(1)
selectionInput.selectionFilters = ['Features', 'Occurrences']
#Once thread feature has been selected retrieve the thread pitch and thread size e.g Size M6 ; Thread 1mm.
Thank you in advance
JeromeBriot
Try this:
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        try:
            selection = ui.selectEntity('Select a thread feature', 'Features')
        except:
            selection = None
        if selection:
            threadFeature = selection.entity
            ui.messageBox('Thread pitch: {}\nThread size: {}'.format(threadFeature.threadInfo.threadPitch, threadFeature.threadInfo.threadSize))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
See ThreadFeature object documentation.
mike
Thank you for the assistance, it's much appreciated
