Get "Sketch Plane" After Importing a Dxf File
isocam
isocam
Can anybody help?
If I manually create a sketch (then extrude it), I can show the Sketch Plane in a message box using a Python script. Everything is OK!
However,
If I import a Dxf file (then extrude it), I cannot find the Sketch Plane using the same Python script.
Does anybody know how I can get the Sketch Plane, if I import a Dxf file and display it in a messagebox?
Many thanks in advance!!!
Darren
BrianEkins
I'm not sure what you mean by "Sketch Plane" and would need to see what your code is doing. I imported a DXF and examined the data and don't see anything strange.
Brian Ekins
